smokehouse
firebird990
lewiston idaho
i have some 4x8 galvinixed steel panels that i thought would make a nice size smokehouse.the inside would be line with plywood. the smoke and heat source will be wood pellets.what are your thoughts on this.has anyone here ever built one?
frank001
Southern California
I wouldn't use plywood. Who knows what kind of glue they used that could off-gas and get into the meat. :shocking::shocking:
tarmy
Nor Cal
I know welding on galvy material releases some very nasty chemicals...maybe some research on the temp it is safe to use for intended (food or edibles) purpose?
matt_i
180° is roasting, not smoking.
80° is smoking.
Lol, the meat won't even cook below ~200F air temp...I target 225F chamber temp when smoking pork butts.
I'd recommend materials like raw wood and plain carbon steel. A little hot rust never hurt anyone :)
Showkey
"MEMBER EMERITUS"
Wausau WI
80° is smoking.
An old gutted one door refrigerator is the best thing you can do for yourself.
Cabinet is pre-made, adequate and easily lined with your choice of anything but plywood.
I'm going to suggest some YouTube videos be watched about smokers and smoking.
So Far All I've really gathered is that you're trying to salvage some galvanized.
Don't salvage the galvanized...
Coldsmoke vs hot smoke
A general rule of thumb: Cold-smoke ingredients to impart a smoky flavor to food that doesn’t need to be cooked (e.g., dairy products like butter or cheese) or that you plan on cooking later, on the grill or in the oven; hot-smoke ingredients to both flavor and cook them (e.g., meats).
https://www.chowhound.com/food-news/55599/whats-the-difference-between-hot-smoking-and-cold-smoking/
gbfan10
Minnesota
The place I just purchased has a dedicated smoke house on site. It is made out of metal and looks like a small car port. It has a temp gauge and a small fire pit in the middle. I am not sure how to run it yet.
ynned
N.E. Ohio
Pellets for the smoke? Don't they contain glue, or at least some kind of binder that might be iffy to eat?
nes999
IL
It won't begin to off gas until 450 degrees.
Sent from my VS988 using Tapatalk
sqznby
Coastal NC
Man I wish I knew more about smoking (food).
I did some work for a guy who built this crazy smoker, basically built a shed out of hardwood. Dug a ditch to fit cinder blocks and used the holes in the blocks to run the smoke into the bottom of the shed. At the very beginning of the ditch he dug a big fire pit with a block top. I'll see if he can send me some pictures. Better yet. Google "shed style smokehouse" you'll get some awesome ideas. Plus the links above are a wealth of knowledge.
