Smoothing Rough Finished Concrete Floor
dvcochran
I have a shop area that is 672 sq/ft that has a very rough broom finish. The area has been converted to add an additional work area but the rough floor makes it hard to roll around on.
What is the best/easiest way to give the floor a slick finish? Once this is attained, should the concrete be sealed or coated?
Thank you for the advise.
LegacyIndustrial
deerfield, IL
Diamond grind the texture off and apply a polyurea coating system or our SECII SEALER will work, 2 coats, resembles polished concrete.
That texture will grind easy but will make dust so get a vac system to go with the grinder.
Good luck
nadogail
Coronado, CA
Have the floor ground with a Diamond Grinder, you can have a flooring company do it as part of the prep for an epoxy floor.
