Snap on 15 ton capacity press prices?
WickedMainer
Is $250 for an older snap on 15 ton capacity floor press good? The jack in it is a 10 ton model I believe. I thought it was a steal and figured it would be gone before I could get there but it's still for sale a week later and just reposted. now I'm a little confused. I use my buddy's press currently but if this is a deal I may go get it for my future shop. If it's only an ok deal I'll wait, I'm content on the harbor freight 12 ton, but like to buy USA made or tools based on resale value should I ever need to sell
Lwel9226
So Oregon
I just bought a HF 20 ton for $145. (with a coupon)..... Makes $250 for a used 10 ton sound a bit much...
Lynn W
Sycan
If I was in the market for a press I would probably be all over it. I'm sure the snap on will be a rebranded american made press, but would be way better than the harbor freight version
W
WickedMainer
Lynn W
That is why I am hesitant, but my decision hinges on the resale value of the snap on. I don't tend to calculate the cost of a tool by how much the purchase price is I calculate it by what I lose if I sell. I guess my other question would be is what makes snap on presses so special to be over 5000% more on something that's little more than some steel and a bottle jack( other than service, and the logo)
W
WickedMainer
Yes it is usa. And I am one of those who tries to avoid foreign made tools. I'm content with the hf if nothing comes up since it's what my friend has. My neighbors press however takes much less time and effort to get a job done doesn't have as much movement and can set the height easier. I like having the foot pedal too....
Sycan
I would guess the snap on will be worth the same amount in 10 years, the harbor freight worth about $50
Sent from my HTC6535LVW using Tapatalk
WWheeler
Middleofnowhere USA
^ This. The Snap On might even be worth more.
You're more liable also that Snap On will offer support and replacement parts for it if needed, You won't get that with HF.
HF's replacement parts plan after the 90 day warranty is up is 'buy a new one'.
454ragtop
Carver, MA
That Snap On press is nothing special, bottom of the barrel A frame bottle jack press. If you keep an eye out, can probably find 1 of the 20 ton USA made bottle jack presses for less money. I have one of those, paid $150, wouldn't trade it for that Snap On, even with $100 coming my way.
Buckgnarly
VT
I know the one you are talking about, not sure I'd pay 250 for that... maybe like 150ish..
469 runner
North Carolina
Is the press you're speaking of like this one? If so, I would jump all over that for $250.00 I found this one on Craiglist locally for $225.00 It is a 20 ton. There is no comparison between the Snap On and Harbor Freight. The Snap On is superior in every way. The steel even says Bethlehem Steel on it. The hydraulic system is outstanding. I liked the press so much I powdercoated it.
Finky198
North East
Just buy the HF 20ton at 145 bucks it's a killer deal and you can custom build it however you want. We bolted it are together got it square and welded the top frame. I boxed in the legs and added caster and cut plywood to fit 2lg milk crates to hold steel blocks wedges and tons of round stock. Finally added a hoist and pulley system to raise and lower the deck. You can go as far as you like.
In the middle of building it
Just a question why are you so worried about the resale value youve got to buy one and use it before you sell it or need to upgrade to something larger if need be and in reality that would still not be good reason to get rid of it. The tool is not worth what you paid for it. It's worth is in how much profit it can generate.
454ragtop
Carver, MA
I'd jump all over that one too, unfortunately it's nothing like that, it's an A frame style bottle jack press.
Buckgnarly
VT
Not even close, that one I would have already grabbed it.... for double the price to have Bethlehem on it
!:lol_hitti
fastbike02
Walnut Grove MS
where'd you get the pulley from? I have my hf press on wheels but would love to have a cable driven lift and lower
pi_guy
N/A
Most of us buy tools to offset costs or have a revenue stream from it. Not how much are we going to loose if we sell it.
Construction and fabrication methods are one item that will drive up SO prices.
But if you look at a SO image posted the ram floats back and forth none of the HF stuff does that. There is a whole bunch of reasons and if you have used good equipment that will be your best guide. But from my view it seems if the thing has the same name it must work the same way syndrome here at GJ ..
Honestly I have tried HF numerous times and the failure rate is just not acceptable. My last HF failure is the greenlee styled hydraulic punch set on the first punch distorted the metal and left a burr and the hydraulic unit dripped oil like all the hydraulic stuff does. I bought the greenlee one with mechanical press and perfect holes no distortion.
Finky198
North East
The winch I had laying around the shop not sure the brand but there's available at tractor supply Harbor freight and the like. I notched the pulleys and welded them to the top corners than welded a screw link to each side of table and ran a cable down and crimped ends. It's the best mod I have done take most of the work out of using it....
^^^^Man you obviously are not an HF fan but the press has proven itself on here just like there tool boxes have. no it's not a 1000 or 1500 dollar unit which I think is and absolute rip off as most guys think snap on is. They both accomplish the same thing they apply force just one does it at a 1/10th of the cost.
The floating head you speak of which is so helpful... I've use only twice in my entire career. neither of which job would have covered the difference in price... Maybe if you own a large machine shop it would make sense, but for the small fab shop or mechanic it would be total overkill to spend that kind of $$$ and finding a used one near me is rarity not to mention with the asking prices for a press like your talking in the 750 to 1000+ Your getting a pretty raw deal.
oldtools
There is nothing special about the SO press. It is made by somebody else. There are better deal out there. Look for Nugier, OTC, Dake, Baileigh, etc.. I bought a H-frame Nugier 12 tons for $100. The Nugier 12 tons is beefier than the HF 15 tons.
tool_scrounge
Southern California
+1 on the 12 ton Nugier press. I found one without the bottle jack for $20. The steel c-channel is 2x thicker that the bent metal summit Taiwan built 12 ton press I owned. Made in Los Angeles too (and still in business). Now to find a quality bottle jack to put in it. Currently considering a Norco (Japan) or US Jack (US).
oldtools
My Nugier has a cheap bottle jack so I replaced it with a 12 tons Norco bottle jack. I try putting a Norco 20 tons, but it won't fit. The Nugier H-frame is over designed for a 12 tons. I want a 20 tons Nugier H-frame though.
justanengineer
Motor City
JMO but I would be surprised if the press in question was US made, SO sold many rebranded Asian tools off the truck going back at least to the 90s and that looks like another import to me. I probably wouldnt go over $100 for it.
Hiball
Missery
I'm not familiar with that Snap on A frame press, but rest assured any tool that comes from Hydramec (Oem for Snap on) is top of the line, including there presses and pullers.
oldtools
Hydramec make top notch tools for SO, but they are equal to Dake, Nugier, etc. Don't pay a premier because it has SO name on it. For example, it is better to buy a used Dake 20 tons press for $500 instead of a used SO 20 tons press for $700.
Hiball
Missery
Sure... No one is saying Dake or Nugier Presses aren't quality Brands. I can't speak for everyone, but when I'm shopping for a piece of equipment, I try to approach the item with open eyes. I base my pricing off overall condition, including build quality, signs of abuse, replacement part availability. I won't dig into your pricing examples too much, As I've already explained there are many variables. I only gave $120 for my 60's Snap on Press (+$35 for Seals/fresh Oil), it was a steal and few and far between in my area in regards to Presses. I would have happily drug a Dake or a Nugier press home for the same price and condition.
oldtools
I believe all Nugier press are made in US. I believe all Hydramec products are made in US as well. Not all Dake products are made in US, so if anybody is concerned about COO, check the COO before purchasing.
454ragtop
Carver, MA
Is that A frame bottle jack press made by Hydramec? I think people keep seeing the Snap On name and think this press is something it's not, probably what the seller is hoping I'm sure.
Hiball
Missery
I can't say for certain, it appears it's not a current production for sure. I'm leaning Towards NO, but it is Red.. Ha.. You know the gig, Someone could have repowered the press with a Snap on branded Jack and Here we are. I didn't go thru the entire Hydramec catalog, but the majority of the presses use a hand pump/Cylinder versus a bottle jack.
I'll check my manuals when I get a chance, I suspect after reviewing things, this press is from the Lincoln family era when they OEM'd lift products.
