Snap On 3 Ton Arbor Press CG100 Thoughts
lafester
Northern CO
Looking at one of these if the price is right since I can't find anything bigger then 1/4 ton in my area. It's an interesting design and may be handy for some odd sized work.
I see nothing, anywhere on these except one lone video.
Anybody have one, used one or just seen one in the wild?
Only Youtube example:
https://store.snapon.com/Arbor-Press-3-ton-Arbor-Press-3-Ton-P636461.aspx
Description
• Frame is 2" steel channel – bolts to work bench
• Gearing multiplies handle pressure up to 3-ton force
• Set includes arbor press frame, utility punch, work block and adaptor to convert 1/2" drive to 5/16" round drive
• Optional accessories: The adaptors from A57Q bushing driver set can be used with CG100-16 5/16" round drive adaptor – the CJ951 bearing separator fits neatly between the work support brackets
Product Specifications Information:
Base Size 11-1/8 x 6-1/8"
Dimensions 11-1/8" W, 18" H
Opening Width 9"
Pressure Shaft Stroke 9" (when utility punch is attached)
Pressure, tons 3
Vertical Capacity 12-3/4"
Width Between Work Brackets 9"
Country Of Origin USA
Brand Snap-on
Skin
Boston
That's a bucket of money for such a tiny press which im sure is why you cant find much about it. Dake B-10 can be had for just a bit over $300 any day.
L
lafester
Northern CO
Well sure, if you buy from Snap On.
I don't want a hydraulic so the B-10 is out. That is kind of cool though.
Looks closer to $400.
L
lafester
Northern CO
Keep in mind I am not going to pay anywhere near retail for an arbor press.
Pretend I found this on the curb and give your thoughts on it's usefulness.
johninct
Very useful for very light pressing jobs such as pressing in bushings where you need feel and control so you don't break something.
L
lafester
Northern CO
Well I got the press and a Wilton 1760 for $250.
Not as good as finding on the curb but not bad.
The 1760 is missing the end cap but it was the only one with the cast 'made in usa' which I liked over the plain ones.
Auction pics... pick up tomorrow.
L
lafester
Northern CO
I like the vise! Should be big enough for anything I throw at it. The press is interesting, can't wait to try it out.
Sent from my Pixel XL using Tapatalk
L
lafester
Northern CO
Yeah they had 4 vises and all got bid up.
Was hoping for a better deal since it was in Pueblo.
L
lafester
Northern CO
I see posts for almost every other Wilton on replacement dust caps but none for this one.
I measure 2 7/8" for the ID and see only a few options for this size.
No nice $50 caps available from wiltonviseparts
There is a freeze plug option from dorman 555-112
There is a close match (but slightly too small) for a nice domed axle dust cap: brakebest rg04-100
They found an alternative, right size but kind of cone shaped cap: dorman 13914
Last thing I found is 2 7/8 pipe caps: https://www.ebay.com/i/113144848597?chn=ps
Currently trying to get the brake best to fit, may have to do some grinding.
Provincial
Near Salem, OR
It looks like that press was designed for a special purpose. The 1/2" drive adapter for the arbor indicates that it was designed to fit sockets or adapters to apply torque while the press applied pressure to keep the bit/socket engaged with the fastener. I'm thinking removing/replacing field coils on starters and generators as an example.
The design of the frame limits the size/shape of the work, but that will only be an issue for large or odd-shaped objects that won't fit into the frame. You will have to make something to support your workpieces, but that should be straightforward.
Now you have another project!
L
lafester
Northern CO
Going to dig into the press a little and see why the bar comes down at an angle. A little pb blaster and then some new lube and it turns nice and smooth.
The handle is missing a pin on one end and I'm not sure if it is supposed to have a set screw to keep it from sliding.
I'm sure each use is going to have different support needs. First thing I need to get is a good sized bearing separator to fit between the support brackets. I'll probably make up some spacers for those brackets as well. I have some 2" square tube I can cut up as well. For the most part I will just have to make stuff as needed.
L
lafester
Northern CO
Ok, one of the bolts was bent so I found a replacement and it is much better. Now I'm wondering how much force was used to bend that bolt. That is obviously the weakest point on this design. I'll grab some high grade bolts next time I'm at HD.
Also cleaned up and flipped the vise jaws. I think they will work for awhile longer although they are a little beat up. I did confirm Kevin does not make end caps for the 1760.
L
lafester
Northern CO
I wish it fit sockets! That would be a nice feature. The adapter goes from 1/2" round to 5/16" round.
Overall I think this frame will be more useful then the standard arbor press form where you only have a few inches of room before you hit the cast iron wall. Also much lighter to move around. Now if I find a nice ratchet, compound 5 ton press for a deal then maybe I'll switch to that. Of course there is also the 5 ton hydraulic mentioned above. Those look pretty nice.
Going to start with the big HF bearing splitter and go from there. I have some small pieces of angle iron and 1/4 inch plate I can use to make some sort of adjustable base.
