Snap on air rachet has no power
JUNK-MAN
PA
As some of you may know from another thread I recently scoured a Snap-On air ratchet (FAR72A) wen I originally tested it I just listed to it but didn't pay attention to the working parts it sounds fine but the head don't want to spin and when it does it has no power at all. I don't want to tear it apart with out some sort of break down guide so I can get it back together correctly and even if I did I wouldn't know what to look for, so my question is what commonly goes wrong with these and what causes them to loose almost all power? A friend of mine suggested it was clogged up and wasn't getting air or maybe just needed oil. I oiled it but it did nothing for it, is the not getting air thing an option? Any help is appreciated, Thanks!
Some air ratchet use a ball in their trigger mechanism. The ball rusts and the won't set properly. Get an exploded parts view and check it has a ball.
MFolks
Springfield Mo.
When using any air tools,(except inflation and blow nozzles),I put a few drop of Marvel Mystery oil down the connection, to lube the mechanism. It will help to prolong the tool's life.
Wamsutta
Amarillo, Texas
If it has a silencer in the exhaust, try taking that out and see if the power increases; if that doesn't help, it may need new air vanes.
stevenhs
Orange county, CA
I bought a same one on ebay at a cheap price, but it did not work. So I sent it in to have it rebuilt (last month) It cost $130 to rebuild it
J
JUNK-MAN
PA
Yeah I was going to rebuild it but its not worth that to me, If I cannot fix it with something small and cheap I sell it to someone who wants to take the time and money to rebuild it.
lynnbilodeau
Oklahoma
I would follow the advice in post 2 above before bailing.
Doesn't have to be Kroil. Could just be trans fluid, MM oil, tool oil, or any thin oil.
Hold it vertically, with the air fitting up. Squirt oil with the trigger held in until it starts running out. Then release the trigger and fill it. Let it set that way (standing up) for a day or two. Turn it over so the air fitting is down, hold it over a drain pan and pull the trigger (or push the button... whatever terminology works for you) and let most of the oil drain. Before you attach an air hose, wrap the tool in some old rags (this is messy) and try it out. Run it until it is no longer spewing oil.
That is a very powerful air ratchet when working properly. I had one for many years. I actually prefer the older FAR7012C model, which is faster, but with less torque when you hit the end of the run. I got one for $10 a few years ago because it "didn't work". Did just what I described above and it works perfectly. Every time I use it, it gets one drop of oil.
Good luck.
J
JUNK-MAN
PA
Good luck.
Will WD-40 work?
J
JUNK-MAN
PA
In my experience WD40 doesn't work for anything but squeaky hinges and as a rather pleasant deodorant. If you don't have Mystery Oil, Kroil or one of those I would get some ATF.
If Kroil, being the first mentioned and tested were could I find it?
J
JUNK-MAN
PA
I have ****** fluid, how would I do it with that? pour it in with a small funnel or put it in a oil can?
maxpower_hd
Massachusetts
In an oil can will work, or a small air gun oil bottle. I don't know that model but I had another brand a while back that acted like yours and it was the trigger like mentioned above. I was able to take the trigger out, free it up, clean it and lube it and it worked fine.
J
JUNK-MAN
PA
Huh, will have to find a parts break down and see if it has a ball in the trigger. Hate to ask so many questions but, can just dumping a **** load of oil in it hurt it at all?
