How are these better than taps and dies?
Thread restorers like these are less likely to undercut good threads. They are made from softer steel and the taper is designed to "find" the good threads and line up the tool properly. Most often the first few threads are the ones that are damaged and it is easy to start cutting new threads slightly offset from the original ones when you use a standard tap/die to restore damaged threads.
There is nothing wrong in most cases with using standard taps and dies to restore threads as long as it is done with care and as long as the tolerance of the tap/die is not sloppier than the original threads in critical applications.
It depends on your purpose, these are more for repairing threads, and don't contain the axle nut sizes. (these are like a spark plug chaser)
rsanter, it's the apostrophe in the name that makes the huge difference, not the two letters by themselves. Sears = Sears Holding Company, or something like that, so technically Sears has more letters than Snap-On.
It must be the apostrophe!!
Very thorough reply, MAD. Thanks.
When are the Snap-On guys going to chime in and explain that Snap-On is not being greedy, their stuff is really better, the guy comes to their shop, blah blah blah...?
We wont because of people who constantly seem to bash Snap-On and continually argue that Craftsman.Mac/Matco whatever is just as good.
I have a set from SO and a guy at work has a set from sears...SO replaced a single broken die for me and sears wouldnt replace a broken tap for the guy I work with. is the SO all that much better? Probably not..but their warranty sure is.
DDM
DDM
mmmm...
did not know that was covered
that might make me buy the SO over the other guy
bob
DDM
You can't put Mac & Matco on the same level as Craftsman. they are both a better product.
I've always been told that if an item carries the Snap-On brand name that is made by Snap-On.
If these aren't made by Snap-On, I wonder why they don't have a Blue Point brand on them.
I have the Snap-On set.![]()
