Snap On ball joint press?
Jason280
Is the Snap On BJP1 ball joint press set enough of an improvement over the OTC kit to justify the extra cost? Local shop has a kit for around $200, but I already have a USA made OTC set...will I notice any real difference?
rlitman
Long Island
OTC probably made the Snap-On set.
They don't at all resemble each other. From what I can tell, Snap-On makes theirs in-house.
I've heard lots of great things about the BJP1.
Personally, I've got a knockoff of the OTC. One thing I did, was copy Snap On, and drill and tap a hole into the side of the thread collar, and install a grease zerk. It really helps.
nbruno
If your current press has been used and has remained square and straight there is no reason to replace it. OTC makes some quality tools so you're probably not missing much.
If you had a harbor freight and were looking to upgrade then yes absolutely, but the otc should be fine.
I have a Matco BJ press that has worked beautifully dozens of times, the HF press didn't make it through one set of ball joints.
J
Jason280
I like the idea about adding the Zero fitting, may have to give that a try...
Mr Ratchet
I have at least a dozen pushes each through cheaper Powerbuilt, HF, and some other no name unit. No problems with any of them. This would be one of the last tools I would spend a ton of money on. If I did them every day, maybe depending on how the cheaper ones held up.
zmotorsports
Northern Utah
Incorrect. Not even near the same in quality nor adapters required.
I have both the OTC master set and the Snap-On Ball Joint press and since purchasing my Snap-On BJ press a few years ago I don't even think I have opened the OTC press. I love the Snap-On press and highly recommend it.
Hiball
Missery
If you passed on a Snap On ball joint press for $200, you should stop what your doing and immediately go get it, Then again it’s probably gone by now. I’ve sold probably 10-15 of those sets and the least I’ve ever gotten was like $400 for a complete set (heavily used) with cracked case.
Two Door
Houston, TX - USA
I've read several of these threads where some of the posters have both styles of press. Every one of them says the Snap-On press (about $700, as I remember) is worth it, but I suspect they are in a professional environment. If I could get one for $200, I probably would!
Edit - The post from ZMotorsports is typical of what I've seen.
chrisnazzy
Arizona
Yeah $200 for a complete BJP1 set would have been a "you ****" deal. As others have said it is highly regarded as the absolute best out there.
Buckgnarly
VT
Own both OTC and BJP1....I hope the OP is talking about the old Snap On style and not a BJP1.....if not, you passed a SMOKING deal. BJP1 is in its own league!
kythri
Lebanon, OR
If there was a BJP1 kit anywhere near me for $400, I'd be all over that. $200?! Absolutely no question.
Not knocking my OTC or Astro kits, but, yeah, the BJP1 kit is most definitely one of those places Snap-on excels.
J
Jason280
Well, you guys have convinced me...I'll swing by tomorrow and pick it up.
Tech89
I have one. Absolutely awesome and lifetime warranty. I broke two OTC presses prior and then got my BJP1. Just be sure to keep it well lived. I had to have my C press and Screw warrantied once.
-Pat
Sent from my SAMSUNG-SM-G891A using Tapatalk
GTA Matt
Zebulon, NC
For 200 bucks I'd knock my own grandmother out of the way to get my hands on one. I have the otc and the bjp1, again, the snap on is well worth its price. My only regret was not getting one sooner. The otc did get me through hundreds of jobs without a problem, but the snap on can really save some time and frustration.
Jlbc212
Northeast MA
I'm just a shade tree mechanic and I own the Snap-On press. It's the only Snap-On tool that I own. I only wish I had the smaller cups to press out some of the smaller ball joints like those on a Honda Civic.
psychob0b1977
Dracut, MA
I have the snap on bjp1 kit and I can't recommend it enough! I am only a family mechanic so it doesn't get a whole lot of use.
On one truck I was working on, a Ford 4x4 with the ttb front axle, it was literally the only tool in the world that could complete the job the way I did it, saving me several hours. On that truck you have to pull the differential apart to remove a clip to replace the u joints in the axle. But not with the snap on bjp1. The way the press is shaped, you can fit it on just right and remove the u joints while still in the truck! Saved me hours of labor!
jchetty
Central New Jersey
:lol: Wait, what?:lol:
Not even in the league. I did front ball joints on 2 cars befor lunch. I am no mechanic- the BJP-1 is one of those tools that when you need it you need it.
Right up there with my induction heater. Next time I do springs, I am buying the Branix spring compressor. I do it to save money and save my sanity. I buy tools that allow me to safer and faster.
BiltFordTuff
I have the Snap On BJP1 and i absolutely love it. Havent ran into a situation that it wouldnt work for me yet. All the adapters snap together so you dont have to try and hold them in place while you are tightening it. Makes ball joints and u-joints a breeze. Highly recommend it.
Ole Slewfoot
Freedom, CA
I had to make an angled adapter for the 1ton AAM axles. I know SO makes one, but I was off in the woods and had an old bearing. I have a few bearing parts in my BJP case to increase the size ranges a bit, and a fishmouthed pipe that fits driveshafts. I use it on quite a few control arm bushings too. I'd probably use a shop press for those if I did't work out of a truck though.
L.Cheapo
You'll notice a lot of difference...
When you have all the adapters stacked on and they don't fall off
When you hold the massive C frame of the press
When it doesn't bend, strip, or go ****-eyed on you while using it.
When you can get 99% of the vehicles out there done without 100 different adapters
J
Jason280
I picked it up this morning, ended up costing me $225....still not a terrible deal. I'm interested in seeing how it compares with my OTC , may end up having to do the ball joints on my F550.
Buckgnarly
VT
A complete, good shape BJP1!?.....please allow me to be the first....YOU ****!
You will laugh at the OTC after using that thing.
psychob0b1977
Dracut, MA
Definitely worthy of a you **** at that price!
redwrench60
East Tennessee
You can tell who has and hasn’t actually used the Snap On set on by the responses in this thread. I used the OTC set for years and got by but after trying the SO set on a variety of vehicles on balljoints, driveshafts, control arm bushings and various other intermittent tasks I realized how versatile it really is.
The user friendliness, versatility and brute strength it has makes it the best in the business. It opens wider than the OTC, has a deeper c-frame throat depth, has better thought out adaptors and it’s reversible so it does most balljoints without removing the control arm.
montanafordman
Meridian, ID
Yep. You ****. I have used an OTC knockoff before and it worked so-so. I had another job to do (and I"m just a shade tree home wrench) and sprung for a BJP1. I had been following them on Ebay forever and when one came up for $425 shipped to my door I jumped on it and have no regrets even though that's much more than I'd normally be willing to spend on a tool I don't use that often. I also liked the fact that I don't need so many adapters (basically 2 cases between the press and the adapters for an OTC kit) taking up all the room in my toolbox. If it cuts down on the time I need to do a job, and makes it more fun its worth it even for a shade tree guy like me.
Rubiman14
Greatest thing since sliced bread! Love mine
Awesome score!
