Snap-On Bedliner Top vs. Stainless Steel
The Critic
CA
The older Bedliner tops were prone to peeling, but I have been told that the newest ones have the issue resolved. Supposedly the newer material is also a bit smoother?
Curious what y’all think.
The stainless steel is easier to clean, but Bedliner looks better.
AEAdam
SE PA
Stainless! Well...er...I guess it depends on how you use your toolbox. I rebuild messy stuff on mine and wipe it clean with spray cleaner and a rag. If you just use it to set things, the bedliner might be perfect. But it's not really wipable, and you can see stuff you spilled on it easily. I think the new stuff you are thinking about is legit LINEX and I have that on my truck bed. We use it for armored floors for helicopters at work. Rather have it as a walk surface than a work surface.
msbytes
Former coworker had a Master series with a bed liner and has problems with it peeling. Had it warrantied once, then next one started doing the same. I would go for stainless, but I don’t do work on my toolbox. That’s what benches are for.
charbar
Midwest
Stainless all the way. Easy to clean oil/grease/dust off of it and you can write on it.
