Snap-on , best , new or old logo
OUTRIGGER
Hi, must have been covered in a old thread :D
Just wondering , what is the consensus of opinion on the new style spanners , or should I say combination wrenches :eek:
I was once reliably informed that just because they have USA on the reverse side does not mean they are still manufactured in USA :headscrat
Most of mine are Old Logo - going back over 30 years but I have some newer ones where the size is embossed on the open jaw end , these seem to have stood up OK with little wear or chrome chipping off at the jaws.
I find that some of the CAN or Canada marked spanners have chipped chrome off at the ring end too , seems the genuine USA manufactured ones were superior.
Thanks
lbgradwell
Oakville, ON
I was once reliably informed...
No you weren't...
I'd suggest the Canadian examples you've encountered were likely just used harder and/or longer. I've never heard any suggestions the Canadian production was inferior...
O
OUTRIGGER
Thanks , I am dumping my worn but serviceable Snap-on stuff in a small garage I use for dismantling , OK for rusted stuff & the odd rubber / copper hammer blow.
I will be replacing some common sizes I use all time inc. " AF that I still use.
Will try and obtain good / very good condition on eBay or new new logo as they come available.
So , it seems that what I have , 1. very Old logo 30 years + 2. a few newer ones where the dimension is indented on the OE , also the new Logo where the size is marked on the shank , can you confirm the material grade and chrome finish has remained the same over the years. btw - I have quite a bit of Blue Point USA , and this has stood up to wear / lack of stretch on OE as good as the Snap-on , however - obviously the chrome plating has soon worn thin. I have tried the Taiwanese manuf. Blue Point , the chrome peels off the OE straight away !
O
OUTRIGGER
Sorry to be a bit pedantic about this , I just wish to pursue the better tool .
I have noticed that my Old Logo , are very well made. Looking at a OEXM 17 USA , the open jaw edges are nice linished with small curvature , this seems to prevent loss of chrome starting - such detail is obviously important . Probably the chrome is a hard chrome like on a hydraulic ram ? on to a coppered base ?
Looking at TWO Old Logo , a WOEX 120 USA 7/16" BS , the preparation at the OE is not quite so good , yet possibly a later WOEX 110 USA 3/8" BS , the edge prep. seems better (the Snap-on logo - is much smaller on this one).
I have recently obtained a 19mm new logo OEXM190B , as good as new , it is noticeable that the attention to detail at the OE edges is not up to the same standard , rounded slightly but in comparison quite sharp.
If - I went for the SOEXM type (teeth at open jaw) , is it correct to assume these are more for heavy dismantling ? Obviously it seems to me that plated fixing hex. heads are going to get marked ?
:headscrat
daddy2coull
United Kingdom
newer ones with the size stamped on the open end? I've been buying for 20 years and haven't seen that on wrenches other than the ones my dad gave me
O
OUTRIGGER
I purchased Snap-on first in 1973 , those with the size marked at OE - probably originate in early 1980's , time flies :thumbup:
I purchased PROTO from 1968 , the tool dealer said they were supposed to be as good as Snap-on , I replied what are Snap-on :eek:
