TheGrooveking
Maybe I am suffering from a bout with stupidity but while doing the brakes on a Toyota Camry I used the CT4410 to remove the lugs nuts - 21mm Matco 3/8" drive deep impact socket - lugs were torqued to 76 ft. lbs. when installed. Yet when I went to remove the caliper bracket mounting bolts which were previously torqued to 79 ft. lbs. using a Matco 17mm 3/8"'drive universal impact socket the damn impact could not loosen the bolts, I had to throw my 3/8" Matco pneumatic impact (500 ft. lb. capacity) on these to loosen them. I even retightend / retorqued them and tried again using a freshly charged battery. Of note the universal socket was only at a 15 degree angle. The CT4410 is rated for 230 ft. lb. removal torque.
TheGrooveking
TheGrooveking
