snap on ct4f light bulb help
cape cod
what type of bulb dose a snap on ct4f test light use i know the snap on part number but what is the regular parts store equivalent
Ramblin Man
Middle Tennessee
If that is the light I am thinking of, I have it, and replaced the bulb with a GM dome light bulb. Think 1970's or 1980's.
Hope that helps.
vssjim
McLean Va.
dome lamp bulbs work fine just go to a display and look around they fit foreign cars mostly, the 211 GM style maybe to thick.
6PTsocket
Look on the base of the bulb. There may well be an industry number stamped there. Let's see a picture of the bulb. There are standard bases and standard globe shapes. That only leaves the voltage and current rating. I assume it is to run on 12 volts. Snap On is not likely to have special ordered unmarked bulbs.
Cargo
Where I hang my hat.
I think mine takes a 6614F bulb. I realize that this is digging up a fossil thread but Google points to this and I didn't see the part number in the other replies.
BobsDynaflow
South West of Chicago
Snap On CT4C test light has a GE 189 bulb, I could not find one, I did use OEM tools # 25020 was on Amazon for $9.18 for 2.
ALSO: Snap On EECT307A0 test light has #6614F bulb, I did use OEM tools # 25888 (lights up red) was on Amazon for $6.59 for 2.
Bob
