hautpot
Got my hands on this mini reciprocating saw for about $250. I haven't put it through tons of work, but it has been sufficient enough for foliage branches and thin iron scrap metal.
It was mainly designed by Metabo, then redressed by Snap-On.
Features:
Blades can be placed in either two positions. The chuck is a fast removal and secures blades well. There is some wobble as to be expected. Jigsaw blades may also be used.
The stop has six notches and is quickly released by the triangle tab. It does not pivot like the Hilti.
After using it once or twice, I noticed the notch on the stop (at the most compact position) has smashed the aluminium housing.
The housing is held together by eight T10 fasteners. It appears to be constructed quite well. Power comes from a brushed motor. The safety switch has a satisfying snap.
Similar models to the Snap-on include the Bosch 12 volt Saw, Milwaukee 12 volt Sawzall and obviously the Metabo PowerMaxx ASE Saber Saw. Most people would be better off with the anything other than Snap-On. Nearly all other competitors have an undeniably better warranty on both the tool and battery in addition to being half the cost of the Snap-On. The Snap-On does fit my hands better and I already have some of the other 14.4 volt tools, otherwise I would have went with Bosch or Makita.
Features:
- 10.2" / 260mm long
- 2.5" / 63.5mm wide
- 5.7" / 145mm tall
- 3.5 lbs /1.6 kgs with battery
- 0.625" / 15.8mm stroke length
- 0-3,100 strokes per minute
- $439.95 USD MSRP
- Tool assembled in USA
- Battery made in Taiwan
I couldn't believe how power hungry that thing was, so I tried all my other batteries and to my relief it was a one time thing. The battery life give me about 8-13 minutes of hard cutting (tested with old batteries and new batteries).
