Snap On F710D 1/2" drive problems
Appleyard
Elkhart, IN
I've been trying to get a rebuild kit for a Snap On F710D 1/2" drive ratchet but Snap On keeps sending me the wrong kit. It's a 1/2" drive in a 3/8" body and the kit they keep sending is too big. The kit is still 1/2" square but The gear won't fit in the housing. It's stamped with an E, so I'm guessing it was made in 1944? Maybe it's been superceeded? I've got to send back some old tools for credit anyways, I'm thinking about tossing the ratchet in too with a note attached and the two wrong repair kits explaining my situation. How would you guys handle it? Dealer is M.I.A. and has been for a while.
G1GRANDEUR
If you send the ratchet in, they might just send you back with updated one. Give them a call.
billymade
New Mexico
plinker
Northern Wi
They do not make the 1/2 drive in 3/8 body ratchet anymore. It's been a long time since they did. Dont know why either, seems like it would be very handy.
I would call or e-mail them before sending it in as you may not be happy with a different ratchet.
snapmom
Florida
The F710D was made to be a 3/8 drive. The E is not a date code, but a stamp from the factory were it was rebuilt at one time. (For awhile SO was rebuilding at the factory). I think its best to send it in for warranty, whereas you may not be able to rebuild it as a 1/2. But you can rebuild it as a 3/8 if you like. Kit number for the 3/8 is
RKRA38ALS
snapmom
Florida
heck, that ain't going to work, the faceplate will be wrong. just send it in for warranty
A
Appleyard
Elkhart, IN
RKRA38ALS
So the factory rebuilt the ratchet to be a 1/2" drive from the original 3/8? That's interesting if I'm understanding you correctly. And do you think they would just warranty it as a 3/8 drive or would they offer me a replacement 1/2?
Part of me just wants to keep it. It still works, but not as well. Young guy at work put a 4ft breaker bar on the end of it to break a diff plug loose. Bent the handle and broke a tooth :twak:
snapmom
Florida
Its hard to say if the factory changed it, or toolman changed it on the truck. Not sure what you would get, but it would be much better than what you have.
RobertMo1988
I just rebuilt a lsf720, and that is a 1/2 in a 3/8 body with comfort grip. the kit i ordered was a RKRASF730. it might be very similar to what your looking for, BUT do not send it in if you want the 1/2 in a 3/8. They told me they dont make them anymore and sent me out a SH80A, 1/2'' drive dual 80 comfort grip. I would email them but dont send the ratchet in, they should send out a replacement no hassle at all....
RobertMo1988
I would Email them with all of your warranty issues and they will ship them directly to your house. They ask if you "feel free to dispose" of your old tools and replacements will be there shortly. I have never had an issue and its worked out great for me, and + you dont have to ship anything!
Rico.
England
Oooo if someone did that with one of my ratchets I'd shove a 4ft breaker bar
up the end of them and break a tooth. :Gun1:
Bart Simpson
The F710D was a 20 tooth 3/8" drive ratchet made from 1970 -78.
The " E " was for EXCHANGE , not 1944.
Snap On used to have a program where they would supply the drivers with rebuilt ratchets so they didn't have to rebuild them on the trucks.
You would give your driver your ratchet and he would exchange it for a rebuilt one .
When they rebuilt them at the factory they stamped an E on them for exchange.
The factory did not change it to 1/2" drive it must of been done by the owner or possibly he had his driver change it out for him.
Here are a few pics of an old F731 flex head that went through the exchange program.
Since it is two pieces they stamped both the head and the handle with an E.
Click pics to enlarge them.
The reason the kits your getting don't fit is because you must of been telling Snap On customer service that it was a 1/2" drive and they were trying to match you up to the right kit even though it is supposed to be 3/8" drive.
If you would of just gave them the part # they would of sent you the 3/8" rebuild kit RKRA38ALS.
You didn't say which kits were sent but I would guess that they sent you regular 1/2" drive kits and the gear in those is bigger than the 3/8" ratchet body so of course they wont fit.
Or they could of sent you the 1/2" in a 3/8" body rebuild kit # RKRASF730 mentioned above but that will not work as the gear is a little larger than those in the older 710 series ratchets.
You can rebuild it to 3/8" drive using the normal kit for it but you would need to get the right cover plate for it and they are not available from Snap On .
If you want to keep it as is and 1/2" drive the RKRA12DC kit should work for you.
If you were to send it in they would probably give you a 3/8" ratchet as they go by the part # on the tool.
If you decide to send it in keep the 1/2" cover plate as they are not available anymore.
I would just rebuild it and tell the guy at work to keep his hands off it or at least use a breaker bar and torch if need be.
Bart Simpson
They sent repair kit RKRA711
That kit is for a regular 1/2" drive ratchet and would fit in vintage ratchets like the S710, etc.
You must of had them scratching their heads when you gave them the F710D part # but said it was 1/2" drive.
Contact Snap On customer service and tell them you need ratchet repair kit # RKRA12DC and you should be all set.
Link to Snap On customer service
http://buy1.snapon.com/snapon-store/customer.asp
I would recommend getting the ratchet repair tool ,part # SPP744 as well as it makes things easier.
Link to repair tool
http://buy1.snapon.com/catalog/sear...nsfr=true&search_type=Part&store=snapon-store
One other thing to watch out for in the future .... billymade posted a link to the Snap On PDF of all the ratchet repair kits .
The PDF list has a lot of mistakes so definitely don't take it as gospel.
This link.
http://buy1.snapon.com/catalog/objects/7800/RepairKits.pdf
Most of the list is correct but when someone updated it they really screwed it up and there are a lot of mistakes so if your not sure it is best to just deal with Snap on customer service.
