Snap on f712 ratchet
Blanco_25
Is there a way to get the head a little more stable the one I inherited from my father is loose.
Thanks
snapmom
Florida
You have to remove the pin, and reset the spring or washer. Sometimes the pin is easy to take out, sometimes you Need a press. You could also put the forks in a vice and see if you can squeeze them in a bit, bet to have some alum. In the vice heads.
If the spring or washer is broke, holler at me I think I have some spares
