Snap-on FCF72
techenthusiast
I have two questions about this ratchet
Can it handle use like the regular 3/8 dual 80? My current 1/4 ratchet is skipping teeth from breaking loose fasteners that are torqued too high... I need to rebuild it. and I don't want this to happen if I buy this too. if so I'll just go full size 3/8
Also do they make this in a lockig flex head version? If so then what is the part number?
Thanks!
Bigblue&Goldie
Thanks!
I don't know that I would be breaking loose stubborn fasteners with one, but they hold up to daily use. Give it a shot and see if it works out; if not, put a new rebuild kit in it (free from Snap On with a phone call) and step up to 3/8" drive.
devoncoolman
quakertown pa
Not meant for high torque applications. Be that as it may they do hold up to daily use just not high torque use. So use a full size 3/8 for breaking loose bolts and use this to remove them. I use my small stuff to break loose bolts when space is an issue but other then that thats it.
blown94conv
Berlin, CT
Good for tight spots, but won't replace a regular one. The handle is too thin to comfortably put a lot of torque on, in my opinion.
T
techenthusiast
I have a 1/4 roto head snap on ratchet that couldn't handle much before breaking.
I know this is a 1/4 body wrench with a 3/8 drive so will this one be as weak as my other 1/4 was?
I'm looking at the FF80 vs this one and they only have a 2 inch difference in length, but what about the strength? Can the FF80 handle more than this? Is the strength difference noticeable? Thanks.
blown94conv
Berlin, CT
The FF80 would probably be a better choice. I got the fcf72 for spark plugs mostly, the headers and long tubes always seem to give me less room then I would like.
T
techenthusiast
So the fcf72 should be treated as a 1/4'ratchet for 1/4 applications and not a 3/8 ratchet?
blown94conv
Berlin, CT
I find anything over a 13mm might be a stretch. It will handle light duty 3/8's work, again the biggest drawback for me was pulling on the smaller diameter handle.
