Snap on fh936a Question...please help
Bmh2888
Can you take out the 36 teeth gears and swap with the 80 tooth gears? Please let me know if anyone has done this
T45
no, alot of people appear to be buying theese used, thinkin they are dual 80s
36t only fits 36t, the 80tooth is a next generation design ::(
...even tho both are fully rebuilt with the kit,
the gear recess and head-shape is different
shockwave
Marietta,ga
You cannot unfortunately since screws are on different sides of head between the 2 36t on selection switch side and 80t on square drive end atleast on the 3/8 size they are
Bmh2888
I paid $40 brand new, youvthink there worth that at least? Never used 36 only 80 are they any good?
pa wrencher
I had the 36 tooth variant. It was picky about dirt. The bottom plate fit kind of loosley. It had to be cleaned often or it slipped. It had a few replacement kits in it. Must be why the screws go through bottom plate into the head on the f80. That must keep the bottom tighter and the dirt out. So far my f80 is holding up good.
