The F100's thinner head most likely dictated changing to a smaller diameter screw. The 3/8 F100 head thickness is now about the same as the Matco 88, so I'd guess the screw diameter is also the same, or close. I haven't seen anyone complaining about excessive Matco 88 failures here, but any of these super long handled ratchets are going to fail if you exceed their limits, and you don't need to weigh 250 lbs to break a 12"+ long 1/4" drive ratchet, 18"+ long 3/8 drive, etc.
Snap On definitely takes failure mode into account and designs for the low cost portion of an assembly to fail before the high cost portion- when possible; then they can just replace the low cost portion of it on warranty. Replaceable screwdriver blades are a great example of how they manage warranty costs.
