Snap on gasket scraper
bratwurst
Wa state
Nothing special but I got this of eBay for 20$, you guys use these at all ?
ChrisLS8
I wouldn't use that thing on any gasket mating surface it's chowdered to hell. I use holders with razor blades or carbide scrapers
doug.j
I have one and use it often. I also use a single edge razor scraper and a carbide Super Scraper. The carbide one requires a little extra care to prevent damaging the surface.
Wamsutta
Amarillo, Texas
The best way to sharpen that is to get a file wider than the scraper.
Push the file into the edge parallel with the handle.
Follow the original angle exactly.
hmmmmmm.....
bear in mind you are dealing with mating flange surfaces on which clearances are measured in tens of thousandths of inches..... not scraping old paint off a sash windowframe.
just my lousy two cents, but I'd pony up $12 bucks and buy a new one. ;)
81turbota
USA
I have a few of the Snap On “carbon scrapers” as they call them. New, off the truck. Brand new they aren’t sharp. I wouldn’t use them for critical mating surfaces, as mentioned above, a fresh razor blade and a steady hand is much more effective.
I use them to scrape road grime and grunge off frames, undercarriage etc.
ChrisLS8
It really looks worse than it actually is
I won't use a scraper that has a single nick in it. If I can see it in pictures it's bad enough. You might be able to sharpen it but honestly the SO scrapers are nothing special
Provincial
Near Salem, OR
Search the internet for "sharpening a plane blade." You use the same techniques and tools to sharpen a gasket scraper.
For what these tools cost, it is cheaper to buy a new Snap-On scraper! But then, there is the satisfaction of salvaging a quality tool.
darkzero
SoCal
I just have the Craftsman scraper set with red handles, the better set (who makes them, anyone know?). But I don't use them for scraping gaskets, not for automotive use anyway. They do come in handy for scraping other **** off.
seber
Deep East Tx.
I just grind a worn out file to a flat end. It takes more time to grind off the teeth than to square the end. Touch up on a stone when it gets dull.
Strouty
Southern Maine
I consider those handheld chisels once they have been used for anything other than a gasket scraper. I will say that most surfaces will have more tolerance than expected, that is what the gasket is for, some things need a tighter seal, but then they usually don't have a gasket at all.
logical
Northern fringe of the Motor City Suburbs
If you grind the angled side down on the flat side of a grinder wheel and then use a sharpening stone to take the burr off the flat side you will have a nice $20 scraper that probably still shouldn't get anywhere near surfaces that need to eventually seal to each other.
I have ruined a few wood chisels using them.for scraping stuff. I don't recall what is was but sharpen it, put it in a drawer and eventually it will come in handy.
Sent from my garage.
bob15
Northeasten, CT
You can also get a new blade for it from Snap On, I replaced mine once.
Just keep in mind that your Snappy scraper is only one type of scraper. Beside that Snap On scraper, I also have a razor blade scraper and a somewhat dull old hunting knife that I also use for scraping gaskets off. Different types and styles for different applications or locations.
