Snap-On Hex Screwdrivers?
Krause
Anyone know if Snap-On ever made any metric Hex head drivers in the same fashion as their normal screwdrivers like they did for Torx?
I've done a quick search but the only thing that turns up is a small set of mini drivers.
jrobb316
WI
I wanted these at one point but are not current production. I got the Bondhus ones and they're very nice. Get the briteguard or the gold, you'll be happy.
Wamsutta
Amarillo, Texas
Black Hard Handle
SDAM2 = 2mm Hex, SDABM2 = 2mm Ball Hex
SDAM2.5 = 2.5mm Hex, SDABM2.5 = 2.5mm Ball Hex
SDAM3 = 3mm Hex, SDABM3 = 3mm Ball Hex
SDAM4 = 4mm Hex, SDABM4 = 4mm Ball Hex
SDAM5 = 5mm Hex, SDABM5 = 5mm Ball Hex
SDAM6 = 6mm Hex, SDABM6 = 6mm Ball Hex
SDAM7 = 7mm Hex, SDABM7 = 7mm Ball Hex
SDAM8 = 8mm Hex, SDABM8 = 8mm Ball Hex
SDAM9 = 9mm Hex, SDABM9 = 9mm Ball Hex
SDAM10 = 10mm Hex, SDABM10 = 10mm Ball Hex
Source: Catalog 300, 1995
SDABM110 = Ball Hex Set, 2mm-10mm.
Mohawk Dave
SoCal
Yep, I got the Bondhus Ball End ProTip and I'm VERY HAPPY. Super comfy and haven't failed, and I've put some torque on them suckers. :thumbup:
I would've got the Snappy ones, but I found the Bondhus on sale on Amazon??? IIRC, for like 40-50 bux or something for both SAE and MM. I'm not made of money ya know.
K
Krause
Anyone actually own these? Found another image of these head on, since they don't have a bolster to hide the slots from the shank, and there are no slots visible, does that make these non replaceable unlike how most Snap-On hard handle drivers are?
Unless maybe the holes are drilled slightly smaller then the diameter of the hex shaft and the plastic deforms to fit the hex shape when pressed in?
DeliveryGuy
Dartmouth, Nova Scotia
I have the SAE set. I've had a couple of the shafts come loose in the handles. I would say that, yes, they do drill the holes undersized and then press the shanks in. There are no "t wings" like on a regular screwdriver handle.
I fixed my 1/8 and 5/32 by crazy gluing the shanks back in.
ChrisPace
I have both metric and standard sets. Use them often in bike repairs. Rc planes use the small standard hex on everything.
