Snap on master line clamp set
Jon.R
Ontario Canada
Does anyone have this set ? I just ordered it and wanted to see how everyone likes it . I know it just came out not long ago , I figured it would be good for me with brake lines on the school bus fleet I work on . Up here in Canada with road salt you are always changing lines .
[/URL][/IMG]
jfcasey
New Hampshire
I bought it on a whim. Unfortunetly the banjo stopper doesn't fit the most common banjo fitting I encounter (p/s pump on toyotas) but the hard line end stoppers work great on brake lines. I have had some trouble getting coolant lines to clamp totally closed with the big clamp which I'm not too impressed with though.
Jwych
Sioux city Iowa
I bought the large one hoping to use it to clamp air lines to test brake cans on semi trailers but it doesn't have enough pressure to pinch it closed against the air pressure :(
Skin
Boston
Bigblue&Goldie
Loudpipes66
Southwest PA
I don't see how the cornwell $50 or the matco $63 are even a remotely better deal. You get two hose clamp pliers with the Snap on plus it's on special this month for $89. If all you wanted were the line stoppers yes the oem is a decent deal.
Skin
Boston
Two posts in this thread just said the hose crimp pliers don't work well.
