Cliff McNeill
Ok I need some help. I have an opportunity to get a Snap-On Master tech set at an excellent price. Owner bought becuase he was in program then dropped out.
Problem is I dont have all the cash. Here is a list of what is included. I will offer at 75% + shipping. If you want it you have to be committed to the sale! I might need to ask for a deposit via paypal so I can make the purchase (might not). If I ask for a deposit and deal falls through I will return via paypal. I have done business with lot of people here an at Tooltalk. I have 100% Positive ebay feedback... http://myworld.ebay.com/sunshine120405
Have to have idea of interest before I commit
check retail price at the Snap On site...
http://buy1.snapon.com/catalog/catalog.asp
Here is what is in the kit..... All pieces said to be like new with only a few wrenches and socket used a few times. Most in packaging. I will be keeping some for myself
# Tape Rule, Inches/Stud Markings, 12 ft. (TPMA12)
# 3W LED 2D Cell Flashlight (ECF201A)
# 3X7 ROW WELDERS TOOTH BRUSH SS (AC5B)
# Adaptor, Industrial Finish, 1/2in Internal drive x 3/8in External drive, 1 1/2in (GSAF1E)
# Carbon Scraper, Rigid, Black, 7/8in Blade Width, 7 5/8in (CSA8C)
# Driver, Standard Shank, Instinct Soft Grip Handle, 1/4in drive, 7in (SGT4BR)
# Extension, Knurled, 6in (TMXK60)
# Extension, Knurled, Friction Ball, 11in (FXK11)
# Gauge, Feeler, Combination Spark/Ignition, 18 blades (.010in thru .035in) (FB316B)
# Gauge, Feeler, U.S./Metric, 25 blades (.0015in thru .025in) (FB325A)
# Gauge, Gapper (FB361A)
# Gauge, Wire Gap for Electronic Ignition Systems (FB303B)
# Goggles, Chemical Splash (GAC1580)
# Hacksaw, Deluxe (for 12in blades) (HS18A)
# Hammer, Ball Peen, 16 oz. (BP16B)
# Hammer, Plastic Tip, 16 oz. (HBPT16)
# Kit, Battery Service, 4 pcs. (2004BSKA)
# Mirror, Round, 14in extension (Mirror: 2 1/4in Diameter) (GA295)
# Pick Up Tool, Magnetic, Telescopic, Chrome (PT5C)
# Pick, Radiator Hose, Soft Grip, 10.30in (SGA173BR)
# Pliers, Adjustable Joint, Interlocking Channel, Industrial Finish, 9 1/4in (91ACP)
# Pliers, Locking, Curved Jaw with cutter, 10in long (LP10WR)
# Pliers, Needle Nose, Vinyl Grips, 8in (97CCP)
# Pliers, Retaining Ring, Convertible, 3/8in-2in Internal, 1/4in - 2in external, 8in (PRH57A)
# Prybar, 16in (1650)
# PUNCH/CHISEL SET/KIT BAG (PPC710BK)
# Ratchet, Sealed Head, Dual 80(TM) Technology, Long, Flex-Head, 3/8in drive (FLF80)
# Ratchet, Sealed Head, Dual 80(TM) Technology, Standard Handle, 3/8in drive, 7 11/32in (F80)
# SCRAPER (PK53A)
# Screwdriver, Ratcheting, Soft Grip, Standard, Red (SGDMRC44B)
# Set, Adaptor/Extension (6 pcs.) (206EAU)
# Set, Cutters/Pliers, 3 pcs. (PL300CF)
# Set, General Service, 6-Point (14 pcs. In plastic tray) (114ATMP)
# Set, General Service, 6-Point (17 pcs.) (317MSPC)
# Set, Metric, Wrench, L-Shape, Hex, Long (11 pcs. in BHK11 Metal Index) (2 to 12 mm) (AWM110DHK)
# Set, Socket, Deep, 6-Point (10 pcs.) (3/16in to 9/16in) (110STMY)
# Set, Socket, Deep, 6-Point (11 pcs.) (1/4in to 7/8in) (211SFSY)
# Set, Socket, Metric, Deep, 6-Point (12 pcs.) (8 to 19 mm) (212SFSMY)
# Set, Socket, Metric, Shallow, 6-Point (12 pcs.) (5 to 15 mm) (112TMMY)
# Set, Socket, Metric, Shallow, 6-Point (12 pcs.) (8 to 19 mm) (212FSMY)
# Set, Socket, Shallow, 6-Point (11 pcs.) (1/4in to 7/8in) (211FSY)
# Set, Wrench, Combination, 12-Point (9 pcs. In tray) (3/8in to 7/8in) (OEX709B)
# Set, Wrench, Flare Nut Double End, 6-Point (5 pcs.) (1/4in-5/16in to 3/4in-13/16in) (RXFS605B)
# Set, Wrench, L-Shape, Hex (15 pcs. In BHK15 Metal Index) (.028in to 3/8in) (AW1015DHK)
# Set, Wrench, Metric, Combination, 12-Point (10 pcs. In tray) (10-19 mm) (OEXM710B)
# Set, Miniature Pick, Instinct Soft Grip, Orange, 4 pcs. (SGASA204AO)
# Set, Screwdriver, Combination, Instinct(TM) Hard Handle, Orange, 8 pcs. (SHDX80O)
# Set, Socket Driver, TORX, Standard, 1/4in-3/8in Drive, T8 to T55 (12 pcs.) (212EFTXY)
# Socket, Spark Plug, Shallow, 13/16", 6-Point (S9704KA)
# Socket, Spark Plug, Standard, Retention, 5/8", 6-Point (S9706KRA)
# Tester, Circuit, for 6V and 12V Systems (CT4G)
# Wire Stripper/Cutter, (AWG 10 to 20), 6" (PWC6)
# Wrench, Adjustable, FLANK DRIVE Plus, Cushion Grip, 12" (FADH12A)
# Wrench, Combination, Standard Length, 1", 12-Point (OEX32B)
# Wrench, Combination, Standard Length, 15/16", 12-Point (OEX30B)
# SCRAPER (PK53A)
