Snap on off set wrenches.
2ndGearRubber
Pittsburgh
A legit wrench will have the part number on it.
Looks like somebody stamped snap-on onto some no-name wrenches. Font is wrong between the size and logo.
mhejl
DFW Texas
100% real. I have a set marked exactly like that purchased off a SO truck in the mid 1980s. Should have "XSM1314 USA PAT 3273430", for example, on the other side, no date code stamp on mine.
The later "A" version dropped the PAT, changed the font (no underscore) and added a date stamp. I can't remember when I purchased the A versions.
The PAT was likely for the Flank Drive - that's about the time it was introduced.
I'd be suprised if anyone would fake an item like this. Yours have the same patina as mine, too. Chrome back then was more of an industrial hard-chrome color, less yellow than later.
drtyler
Odd font for sizes and all, they are legit. Seems to be some in ebay as well.
mhejl
DFW Texas
For those who say they are real, have pictures of them? Also, when did Snap On put "mm" next to the numbers in that font type?
A couple of mine to show both sides. As mentioned previously, these were off a truck in the mid 1980s. For reference, several other styles. All marked with the same patent except the flare nut wrench and angle wrenches (not shown).
I've actually replaced most of the long DBEs. Starting with the "A" version, they're longer. I keep the older ones in the truck.
mhejl
DFW Texas
^^^ Those look a bit less (ab)used than mine. Not bad for probably 30+ years old!
FWIW, I looked up the Flank Drive PAT# above: Granted 1966.
joel63
Central FL
I picked up that set maybe 8 or 10 years ago mainly because it was old script with the mm markings.
I didn't need them since I had a set from the mid-eighties. The mm markings made me grab them.
Coupled with the old logo on the kit bag they sorta had a old time vintage feeling.
joel63
Central FL
Here‘s the mid eighties set. For comparison, the 60 deg. offset has the mm marking.
I don’t like shape of the new one shown at the bottom. 903CDAB5-0343-4FA0-B0F0-CFCC91DC311F.jpeg
