Snap-On PH3050B seems to be hitting light
NorthJersey
I purchased a second hand Snap-On PH3050B. I tried it at 90 psi, but it seemed to be striking really lightly. When I cranked up the pressure it got better, but it didn't have the power I expected. Any pointers?
L.Cheapo
There is a rotary knob on the bottom of the handle. This is the power adjustment. I don't have mine in front of me right now, but I remember setting it was not intuitive. Have you tried turning that?
Are you using hi-flo couplers? What size air line are you running? Is that 90psi the pressure while the trigger is pulled or static?
Chris_Hamilton
I purchased a second hand Snap-O9 PH3050B. I tried it at 90 psi, but it seemed to be striking really lightly. When I cranked up the pressure it got better, but it didn't have the power I expected. Any pointers?
Having no idea the condition you got it in I'll throw this out there. If it was used much and not oiled, especially if the air lines had a lot of water vapor it's possible there is a lot of gum and varnish built up. Try getting some PB Blaster or other penetrating oil, put a couple of shots into it (at the coupler plug) and hook up to air pressure and bump it a couple of times. Then let it sit. Come back next day and do that again. Add a little air tool oil or ATF as well. After a few days if it's gummed up it will be much less so and should have noticeably more power.
Cheapo's suggestion is spot on as well. Check that it's wide open. If it has a built in regulator (likely) then it very well could be set below maximum. It should hit pretty hard as it's got a lot of power.
I'll throw this out there for anyone interested. A good substitute for an air hammer is an aircraft rivet gun. A 3x, or 4x, or even 5X rivet gun has a lot of power and a teaser throttle that allows you to make just a single hit if wanted. It's way way way more controllable than an automotive impact hammer and has the same shank which will allow you to use all your accessories. (.401, bigger ones .498) I almost never use the impact hammer anymore as I love the aircraft rivet guns I have. Good quality ones are available at places like Aircraft Spruce and you can find hi-quality(USA) used ones on Ebay. A 3X or 4X would work well. 5X and larger hit really hard.
N
NorthJersey
It was the built-in regulator! It was set to “I” and I turned it to “IIII.” The thing jumped out of my hand after I fixed it. I have now successfully driven out two exhaust flange studs and, using the Mayhew Shake-N-Break, freed a stuck nut without twisting off the stud. I love this thing! I’ll be sure to keep it oiled. Thanks guys!
On a side note, my little pancake compressor didn’t cycle too much for this application.
Hakeem
Chicago
Wow this is gold :beer:
Mgdoug3
KY
Those shake and bakes are the ticket for rusted bolts. I use mine often on exhaust studs.
NHtoolguy
Gilford, NH
I agree that the Shake-N-Break is a handy tool. I just used one to remove a stuck Subaru pinch bolt. Some heat and and steady torque and the bolt came loose.
