I have an old pair of 96ACP long nose pliers. They are just over 7", no cutter, jaws fall open but absolutely no slop. I have almost no Snap On but love the feel of those pliers. I wanted a second pair. That model is discontinued and replaced with 96BCP, which is also discontinued. The newer one replaced the smooth grips with textured grips, the handles are a hair shorter and the machining design at the pivot was changed but functionally they are pretty similar. The current model is quite a bit different, bigger, recurved handles and different grip pattern on the jaws. I have been trolling ebay for a 96ACP or 96BCP. I just got a pair of used 96BCP that look brand new. The only problem is the jaws were pretty tight. I tried WD40 and Superlube spray. They loosened up a bit Then I thought that I needed something to penetrate the pivot and I tried PB Blaster. As I worked them, a little black stuff came out of the pivot. I sprayed and worked them They are quite usable now but far from falling open. I have two questions. Should they be as free as my old ones or is this considered acceptable. If it is not normal I am open to suggestions. I probably should have bought the similar Knipex that somebody suggested.
