Snap On Quality?
kngelv
Detroit, MI
In the past few years I've broken exactly two tools and both happened within the past few weeks. One was an 8mm Williams USA 1/4" drive socket that cracked holding the upper control arm ball joint of a 2005 Jaguar Vanden Plas while I torqued the securing nut. I used a Koken Zeal after this broke with no issues. The other was a 7/16 Snap-On nut driver that broke while twisting off a bolt on the top of a valve actuator. This was done by hand and I'm somewhat strong but not "that" strong. I've never seen anything like this before.
James
ChefRex
**** breaks when you use it, my SO has been outstanding, when it breaks I get a new one.
I can only imagine how many$ I have warrantied, did I pay up front? Yes but SO has been my only constant dealer.
zendriver
Indiana
About how old is that driver?
Plastic does not necessarily last forever.
I did break a Snap On socket about 15 years ago, but I was yanking pretty hard on a stuck brake bolt.
whateg01
doo dah, kansas, usa
That's what the lifetime warranty is for, both of those failures seem like defects in materials or craftsmanship and not abuse.
If the nut driver was made in the 20th century, I'd chalk it up to aging plastic and just buy a replacement.
If I paid snap on prices because of their warranty, I would make them replace it. And I don't buy new snap on, warranty or not!
Wamsutta
Amarillo, Texas
Williams is not as easy as Snap-on. They'll want you to send the socket in.
As far as the nut driver goes, see if the customer service email portal will allow for uploading photo attachments.
I would say with that picture, it's a slam dunk for a replacement.
What's still not clear to me though is why you chose a 1/4'' drive socket for anything chassis related and I have no idea what a valve actuator looks like on a 2005 Jaguar Vanden Plas.
neophyte
Pennsylvannia
James
These are two completely different types of failures.
One is a steel failure, so maybe that lot of sockets didn’t get annealed enough.
The other failure is a plastic resin failure.
I doubt Snap-On makes their own resin, which means the resin batch might have been bad, or Snap-On screwed ip on the injection molding, maybe by heating the resin ip too jot, causing the resin to become more brittle than expected. Another possibility is that the additives used to produced that particular color made the plastic mire brittle than other colors might have.
Those handles according to Google are dome sort of Acetate compound, and acetate handles usually last decades while still remaining impact resistant, so I doubt that is the issue.
As has been said, one of the main purposes of the tool truck brands is that warrantee replacements are supposedly given Readily, so maybe try that root.
f121
UK
I’ve got a few of those spinners, but not broken any yet, despite getting dropped regularly. Guessing that’s a bad batch.
My most warrantied SO items are screwdriver tips (ph2 tips seem a lot softer than they used to be) and chisels. I’ve broken a few chrome sockets using them on the impact, they’re thinner walled and more fragile than my cheaper sockets.
finn
The UP, God's country
The nut driver came out of a brand new package last year. I guess I’m most shocked on how shallow the tang was. This happened in front of three other tradesmen at work.
James
It would have failed earlier if the tang was larger, as the cross section of the phenolic handle would be thinner with a bigger tang.
Either that or less ergonomic.
My guess is that there were residual stresses in the plastic from cooling too fast in the molding process, aka a manufacturing defect.
Dumber than lumber
That's the whole argument that tool trucks will continue to be around. They deliver tools, provide warranty replacements, and finance all in one place.
It is a good argument. In fact, that is why I chose Craftsman over other brands for 30+ years.. Of course, Craftsman was usually price competitive against most brands.
And we all thought Sears would be around “forever” to warranty the stuff.
Skellyii
KC Area
James
I've had a couple of Snap-On screwdrivers break just like that over the years, can't remember if I was doing anything special.
They were replaced, no questions asked.
