I am considering purchase of a Snap-on 3/8" square drive , traditional steel all chromed. Would it be best to stay with the traditional construction or go for a sealed type. Are the seals just a simple "O" ring ?
In the past - I have just stood the gear-head in a tub of light hydraulic oil.
I more or less gave up cleaning by dismantling , I have a MAC 3/8" with a flex handle that I once stripped and almost lost a tiny conical shaped compression spring
Quite impressed , after a lot of use , the ratchet gear was perfect condition and tiny pawls were unworn
I have worn out a few cheap but good fine tooth ratchets manuf. by such as Heyco. My Britool 40T types (orig. British manufactured) 1/2" drive ratchets have always stood up well to wear.
I would say my worst ratchet experience was a German manuf. Elora 1/2" drive , similar design to Britool , ratchet was very smooth , yet it wore thin on one side of the teeth and started slipping . Beyond economic repair on what they ask for a recondition kit, suspect bad heat-treatment as Elora are supposed to be quality.
Thanks
Thanks
