Deafautotech
Anyone like those? I has use a lot of my fnhf100, tm739, thn739... I had been search for 1/2drive and found on eBay and won it. I just like to have those match set as I am still use it.
I has use a lot of my fnhf100.
Whoa, snapmom! I didn't know they made the road head with a swivel head like that!
Do you use it for everything? I've used mine maybe once or twice. Maybe i'm just not big on those roto-swivels, but it has sat untouched in my drawer for about a month.
I used my fhnf100 today changing oil in the wifes carLove it
Yes. it is great on engine, transmission, and etc... i use it almost anything that i can do. i had to use it to pull the brackets out on F-series while pull engine out as some area that i cant use either FAR72 or Matco MT2858...
I have one older 3/8" drive that I use often. It is beat up, rusted a bit and even has a welding rod gouge on the side if the head, but it works perfect and is tough as nails. I got it free so figured what the hell, I would use it until it quits, but it won't quit.
Where've you been hiding?
Maybe i'll have to give it another chance. I need to put a hard handle on it as i don't like the soft grip. Might do that tomorrow if work's quiet..
Hi there, new to this forum. I just bought a Snap-on F670A and it needs service badly. The problem is, I’m not sure how to disassemble the head. Does anyone know how and would be willing to explain the process to me. I’d really appreciate it! Thanks ~James
These are hard to open. If u take out the guts it is hard to put back in. Try to oil it by letting oil soak in from the top of faceplate. If u can get it open just oil it without taking out the guts. If that does not work u can take it apart.
