Snap-on Semi deep?
slipjointed
How many of you own/use these?
Do any of you use a single semi-deep set in place of deep and shallow, specifically for 1/4" drive?
I had to liquidate my shop, and am putting together the nicest portable tool kit I can, basically the most quality for the least weight and bulk.
I can definitely see a need for deep sockets in larger sizes that my 3/8" stuff covers, but I honestly can't think of a single time I needed deep 1/4" sockets. In fact, in the very few times I possibly could have used them, I just used a hollow shaft nutdriver instead.
Most of the time I'm using 1/4" stuff is either working on a dash, or working on industrial electronics, and 99% of the time it's on hex head flanged sheetmetal screws, or on hex standoffs, and very occasionally on terminal strips.
Anyways, could you provide some specific examples when having both shallow and deep sockets would be an advantage? I'm trying to think of some myself, and they're just not coming.
Americas finest city
I have deep 1/4". Never had the need for shallow or even semi shallow 1/4" sockets. Deep 1/4" sockets for the idiots that install super long studs for carbs or distributors, etc. The 1/4" sockets have a thinner wall than the 3/8's, needed when there are obstructions around the nut/bolt. I bought the deep 1/4's because when you need one, you need it. If theres junk in the way, then it gets a universal socket.
2oolhound
BC Canada
How about adjustments on linkage rods, say a rear brake linkage rod on a motorcycle. 1/4" dr is still within the parameters for this but i know these type things are common in many industrial apps also.
amolaver
i prefer to use 3/8 semi deep for almost everything, but i do find myself needing 1/4 deeps regularly. most commonly it is the long stud problem, but occasionally it just an access/angle thing where they work better. i would rather skip 1/4 short and get semi-deep and deep...
ahm
sf6669
I use a semi deep socket 80% of the time 3/8 and 1/4. I bought them in a combo deal. First set of snap on sockets I bought. I have deep and regular but always reach for the semi. Put em on my bluepoint cordless impact to :pimpflash
redwrench60
East Tennessee
I like my 1/4" drives in deep,semi and shallow because...
A. Human beings like options, I'm a human.
B. I'm using it b/c I can't get my 3/8" impact in there
C. I'm a tool nut and you are too, disagree? You are on a "General tool discussion forum":thumbup:
MadMark
New York City
I had to remove the mirrors on my 86 camaro.
the mirror housing had two 1" long studs that passed through the door sking.
You had to access the nuts through a hole in the inside sheet metal after taking off the plastic inner panel.
A deep 1/4 on a ratchet or breaker could not fit over the studs because the door frame was in the way, only the semi deep would fit between the space and then get over the stud and reach the nut.
malibu101
Walnutport PA
Like many have said above, I too really like semi-deep sockets and use them most of the time. I like to use them because,access permitting, they give you a little more to grab on to, some knuckle clearance, and without being as "cumbersome" as a deep socket. Kinda hard to explain.
DHCrocks
Hawaii
I have 1/4" shallow, semi-deep and deep sockets. I would guess that over 95% of the time i'm only using the shallow. Usually in locations where a 1/4" socket is used clearance is an issue so the shorter they are the better. I would recommend not getting the semi-deep since your main concern is a compact portable kit.
rsanter
visalia ca
I have the 3/8 dr semi deeps in both metric and sae and love them
I usually grab them first if I need to grab and go with a rack of sockets
because they are such a good go between that that usually are what is needed
if I only need one specific sockets I will grab the one that is specifically needed deep, shallow or otherwise
I have been tempted to get the 1/4 dr semi deeps but dont think I would use them enough to justify
bob
G1GRANDEUR
I got 3/8 semi-deep chrome, impact, swivel impact sockets. I grab those first. :)
Fedwrench
Valley of the sun
My 1/4 and 3/8 semi deep sockets are my go to sets unless they won't fit. I rarely use deep sockets. Semi deeps fill the bill nicely. i wouldn't want to be without them.:thumbup:
mrshaun
Killeen - Fort Hood
i go for the semi deep as well and they are making the 1/2 semi deep now as well. look for them in the new products section soon if they are not already there
dave26
WALES UK
I find that Snap-on Semi deep are the same depth as most standard sockets in other brands. Snap-on standard sockets are ridiculously shallow and I would never buy them ever again. My standard Stahlwille sockets are twice as deep as my standard Snap-ons.
William Payne
Wanganui, New Zealand
I think you will find thats not just snap-on thats the difference between europe designed tools and american designed tools. Very different styles.
