Snap-On toolbox ordering questions
diesel_monkey
South-East Louisiana
Hey guys. I'm looking into ordering a new snap on box online because, I can get an amazing deal through student discount. How do they handle delivery? Do you set up a delivery date and general time or what? I tried calling them and was on hold thirty minutes till I gave up so I figured I'd ask some of you guys. And how long does it take, in general, for boxes to be delivered? Thank you guys for your help. Also I'm ordering here in the states.
Wamsutta
Amarillo, Texas
18 gauge steel on the inside walls where the slides mount to. If you ever have to change the slides someday, be very careful because that 18 gauge bends real easy.
If I was getting a new box today, it would be a Macsimizer with its 14 gauge inside walls.
Badger 13
Northern Idaho
Mine was shipped by UPS to a local freight company. The normal UPS trucks can not handle the large sizes, so apparently the semi delivered to the local freight company who has liftgates on some of their trailers. I also read somewhere that some Snap-on boxes are delivered by "moving vans".
AndrewV
Fl
Wtf does that have to do with him ordering a box through snappy s.e.p?
Op, 10yrs ago when i did it, i ordered though the rep at school. It was shipped to my school.
No clue how thay do it now.
warmpancakes
4th letter of the alphabet
snap on has a company dedicated to hauling boxes, smaller boxes come palleted, larger ones are hauled by a moving company, they will call you a few days before arrival, and then the day before arrival. The mover will get it off the truck, unwrap it then have you inspect it before you sign off, Note any damage or problems
Wamsutta
Amarillo, Texas
Because the OP might want to be made aware of the issue BEFORE buying the box. I know that if someone had informed me, I would have never bought my KRL. For as much money as Snap-on charges for their boxes, they should NOT have any 18 gauge steel on the box ANYWHERE.
SquareLJ
We're not turning this into yet another lets bash Snap-On thread.
To the OP, take a moment to look on your local Craigslist for used boxes. I got my KRA2411 from some guy who went management for the same price as I could get it from the SEP, but it came with the $600 stainless steel top and I got some other things from the guy. Or, you might be able to get a KRL for around the same price. Just my $0.02
Edit: And for the record, I had swapped out a slide and changed the order of the drawers and didn't bend anything and I had no clue what I was doing.
colin39
Wow and nobody has been along yet preaching about hf boxes, wohoo.
As warmpancakes says be sure to thoroughly check the box on delivery.
Wamsutta
Amarillo, Texas
I'm not bashing Snap-on boxes. I was just informing the OP of the materials used in the manufacture of the box before he buys it. It is my opinion, and only my opinion, that the boxes should not be manufactured using 18 GA. steel. Any steel thinner than 1/16 of an inch doesn't belong on a tool box in my opinion. When I bought my KRL, I was assuming it would have the same build quality as a coworker's KR1000. I was sadly mistaken.
Wamsutta
Amarillo, Texas
theres alot more to strength than just thickness, a bend in a Piece of 18 Gauge will hold more weight than a flat Piece of 14 Gauge
Yes that's true, but the inside wall of a KRL tool box doesn't have any bends in it except on the outer edges. The cutouts where the slides mount to are straight flat steel. Sure, they put Z-bend strengtheners in between the inner and outer walls, but the inner wall is still 18 GA. steel. If you insert a right angle pry bar into one of those cutouts where the slides mount to and pull, you WILL see the steel flex. The right angle pry bar I'm referring to is the Snap-on special tool part# SPP837 that's used for removing the slides. If you don't pry the slide in the EXACT right spot, you WILL bend the inner wall steel.
jeepinerdeep
South Central PA
I did Mac's student program about 15 years ago.
I already had a job lined up before I graduated, so I called the shop and they took freight delivery of it for me. Service Manager pulled the cover off the pallet and inspected it/signed for it. If you have a gig lined up, maybe this is an option for you.
D
diesel_monkey
I don't plan on parking my pickup on top of my box. So I think it's gonna be alright.
wild cowboy
Birmingham
This is precisely why you don't drink the Kool-Aid for any brand. Research every tool, and only pay for the premium crazy-price brand if it really is better made!
I only buy Snap-On when they have a clear quality advantage over other brands, and only if that quality makes the tool substantially more useful or safer. Torx and Hex bits are a good example. Or some of their diagnostic tools, etc.
So thanks for pointing this out. :thumbup:
and to the original poster - remember, a tool box just holds the tools, any toolbox can do that, saving a lot of money with a much better value toolbox frees up a lot more money to buy ACTUAL TOOLS! :beer:
Adam.C
Good advice from Wild Cowboy, but no analysis or research will be found in this thread of nonsense*. I compared 40" boxes in another thread and found Snap On to be one of the heavier boxes available. Lista boxes are the heaviest; those things are tanks. The Waterloo Pro was comparable to Snap On.
My guess is the sheet metal gages are chosen based on processing requirements and minimum bend radii. If you want tight structural bends, you need thin metal. Snap On, probably like other truck box manufacturers, just uses more of it.
As for boxes not making you money, whoever started that rubbish? Of course boxes make you money. Every time you open a drawer and find the tool you want quickly, your box is making you money. Consider the alternative. No box, multiple boxes, sticky drawers, two handed drawer opening, etc. The only question is whether the premium box is worth the premium price. To answer that, we'd need to compare the boxes more carefully. Can the cheaper boxes actually hold as much stuff? Are the drawers optimized for mechanic tools? What upgrade, trade in, trade up, resale opportunities are there? How will they hold up over time, over rough ground?
*There's very little information on GJ about who actually makes the best tools, or even what the criteria should be for best. When it comes to tool boxes, in my mini review, I compared usable drawer area. Never seen that before. I found some surprises. A 36" wide classic 60 has nearly 20% more useable drawer area than a HF 44 and the Snap On weighs 75 lbs more. The KRA takes up less wall space, stores more tools, and stores more weight in each drawer. I wouldn't use this solely to compare boxes.
So again, I agree with Wild Cowboy, if you have any doubts (and I don't think you do or should) get real data, not hearsay from GJ.
twertsy
Reedville, VA
Not to derail, but I couldn't agree more. Cheap Torx have cost me a TON of $ until I finally smartened up. Did a crapload of research and went with the high-end SK Torx set based on reviews I'd read. Lesson learned about "certain" cheap tools.
redwrench60
East Tennessee
I have nothing constructive to contribute, I just thought I'd post a pic of my "inferior" 18 ga KRL box.......
