- Location
- martinsville va
- Price
- in ad
snap-on 1/4 dr mid length socket set 110TMSY this is a new set never used just been sitting in my box set includes 3/16-9/16 10 pcs snap on 110tmsy flank drive set mid length 1/4 dr $100.00
BLUE POINT FBL325A AVIATION LONG LEAF 25 BLADE FEELER GAUGE .0015 TO .040 This is a 12" long Blue Point feeler gage that is unused. $20.00
snap on b1359b bendix brake tool ford crysler new
For use on Chrysler and Ford 3/4-ton trucks equipped with Bendix brakes. U-shaped end is offset 30° to 45° for easy removal of brake shoe to backing plate spring. 1/4" shank diameter, 6 13/16" long. 9 1/4" long overall. Industrial finish. never used $25.00
snap on steering wheel lock plate remover cg95a Designed for airbag equipped Saginaw steering columns found on GM, Chrysler LH Series (LHS, Intrepid, Concorde, and Eagle Vision), some Toyota, and Saab. Includes two pressure screws: one has 9/16"-18 threads, the other has M14-1.5 threads. The puller is zinc plated. Overall length is 4 7/8". $35.00
snap on 1/2 dr 12pt 19/32 sw191a new shallow socket $20.00
Vintage Lufkin Micrometer Depth Gage 0-6' Wooden Case $40.00
Mac Tools 1/4" Drive Universal Radiator Petcock Socket 7/8" OD Model No PSC300A $20.00
snap on tools c111c ignition tune up set kit bag new $120.00
Parasitic Draw Test Switch Kent-Moore J-38758
brand new never used
Kent-Moore J-38758 is used with an amp meter to isolate parasitic amperage draws on all GM vehicles.
This tool attaches between the negative battery lead and the battery, then the vehicle road is tested.
The next step is to connect an amp meter to each side of the switch, thereby allowing all available current to pass through the meter.
Fuses are then removed one at a time until the circuit source of the parasitic draw is located. $75.00
Snap On Tools new 7-3/8" Red Handled Diagonal Cutters 87CF $35.00
Snap On 6 pc. Magnetic Socket Adapter Set with rack 1/4" 3/8" 1/2" new
$80.00
snap-on tools tool box drawer trim tool $15.00
shipping is free to all you in the states i accept paypal reply if anyone is interested thanks
$80.00
