Snap on torque angle work backwards?
sattech200
St. Joe MI
Hi all. Doing head gaskets on a Subaru boxer engine. I believe Subaru has updated the torque specifications to the values below. My question is, is the snap on torque angle 3/8 safe/capable of measuring angles going backwards?
1 - tigten all to 22 ft-lb
2- tigten all to 51 ft-lb
3 - Back off all bolts in reverse order of assembly by 180° first;
4 - back them off by 180° again.
5 - tighten bolts (a) and (b) to 25 ft-lb
6 - Tighten bolts (c), (d), (e) and (f) to 11 ft-lb).
7 - Tighten all bolts by 80 to 90° in alphabetical sequence.
CAUTION: Do not tighten bolts more than 90°.
snapon: ATECH2F100GB
N8sToolz
180 is pretty easy to count with or without a torque angle gauge.
Those bolts will be completely loose by the end of that second backing off.
dnschmidt
Phoenix, AZ
Easiest way is to mark 12 o'clock on the bolt, I use a yellow paint pen and screw with the initial ********. which to me makes no sense. by simply looking where the mark goes. For the final sequence, which is all that matters, the torque angle will work perfectly.
PCustoms
VT
Everything being a multiple of 90, you could easily do this by eye with a standard wrench.
2ndGearRubber
Pittsburgh
I would not trust it for loosening. It only registers angle if there is resistance. For instance you could not thread a bolt down and register angle applied until the nut hit resistance of the fastener surface.
If the fastener becomes loose enough angle would no longer be logged.
