Snap On torque wrench...am I doomed?
Jason280
I think I have finally killed my Snap On torque wrench, its a 1/4" drive QJR117E. Guess I finally dropped it one too many times, as the lower adjustment "screw" will no longer stay affixed in the handle. Any chances this can be fixed, or am I doomed?
L.Cheapo
I have heard that Snap On will repair their torque wrenches for a flat fee. I cannot confirm or deny that, might be worth asking a local driver about.
J
Jason280
No luck on a local driver, never had much success using them. This was purchased several years ago, and I have not done any business with the local guy. Is there an address I can simply ship to at Snap On?
country83
Don't waste your time with Snap-on, they don't carry the handles for that wrench anymore and it'll just get returned unrepaired. If you want it fixed, I'd give Precision a call as they're the ones that actually made it, and they may still make that style.
J
Jason280
Well, just spoke with Snap On. They will repair the wrench for a flat rate of $59, so I think I am going that route. Not too bad considering it includes calibration!
xurusaibobx
yes snap on flat rate repairs is the way to go with snap on tools. my torque angle wrench cost a little bit more to have repaired and calibrated.
PureLeaf
Make sure you post a picture of the end result when it comes back in the mail repaired!
TheRobotCow
I would just send it to Snap On, $59 for them to fix it and calibrate it? Sounds great to me.
404
Mass
:dunno::willy_nilWhy do you drop a torque wrench... how does that even happen.
J
Jason280
Well, quick update. I received an email last week from Snap On informing me they wouldn't be able to repair the torque wrench, seems like its obsolete to the point that repairing isnt an option. So, looks like its on to option B....me fixing it.
Evan(CA)
That *****. My rep will repair anything for me no questions asked and if it's a discontinued item he will give me the brand new current version.
Lx460
Central Florida, USA
Have you thought about just retiring said wrench and acquiring a new one? I would think with any kind of homebrew repair and calibration costs it may not be practical to repair. Since parts are discontinued and considering its condition, I assume you've had it for a while and gotten fair use of it...
country83
Your dealer may be able to swing you a decent deal on a new one since it's no longer repaired. Corporate gives dealers some leeway on that to keep you in Snap-on.
J
Jason280
The difficulty I am going to run into is getting the wrench calibrated. Is there an easy way of doing this at home, maybe setting up an apparatus that is reasonably accurate? Is it possible to check it using a inch-pound dial indicator? This is the one I have:
country83
My concern with trying to repair it yourself is getting the splined insert to stay tight in the handle. You may not realize it if that comes loose again and throws your calibration off again. Also, IIRC the QJR117E you have is a 40-200 in-lb wrench, but you'd be trying to calibrate it with a Torqmeter that only goes up to 150, leaving you some uncertainty as to where it is when set for 200.
If I wanted it fixed bad enough I think I'd give Precision a call. http://www.torqwrench.com/
