It depends on how you want to change it to black. If you want to remove the brushed trim and install black trim, it is easy enough but will cost a couple hundred dollars to buy the new trim pieces. The drawer trim pieces slide on and off the drawers, but are crimped in place with a special crimper. The vertical channel trim pieces also slide on and off the channels, but are held in place with pop rivets. If you dont want to remove the trim pieces, you can always paint them using a self etching primer and then black paint.
