Snap Ring, C-Clip, No Holes? Tool Identification Help to Remove
YoshiMoshi3
I'm trying to remove this metal ring (red arrow). It's keeping the piece of metal (blue arrow) in.
There is a "+" shaped slot. The piece of metal that is rectangular in shape with shoulders sits in one of the "-" slots within the "+" slot. The metal ring (red arrow) goes around a slot cut into the cylinder (kind of like a piston ring on an engine). It appears to go in a bit on the two sides (green arrows below) but not at the top (orange arrow below).
It goes around maybe 60 % of the cylinder, it is perfectly cylindrical in shape (other than what I mentioned above about it going in a bit at the green arrows into the "+" slot.
At the ends of the ring (purple arrows) on the sides (parallel to the cylinder) it appears to be "/" (left side) and "\" (right side) in shape and not perfectly flat like "|".
Anyone know how to remove this ring? I need some kind of pliers, but not sure which kind. There aren't two holes in the ring for snap ring pliers. I'm not to familiar with snap rings, snap ring pliers, or these types of clips. I've never had to remove one before.
Thanks for any help in identifying the type of plier I need to remove this ring. I have tried regular needle noose pliers, my finger nails and can't remove it.
1982fxr
Phoenix
Two flat blade screwdrivers,
or properly I think they're called duckbill pliers.
Correct tool might be a Horseshoe clip pliers. The outside of the jaw looks like this. Mine are vintage Utica 534-7, and maybe too big for your job.
Hard to tell, your pix are really out of focus to see the ends of the clip.
Overall like this
Xcursion88
Best and safest and most efficient way...
A small flat punch, Hammer and your palm.
In a vise...
Your palm covers the whole unit while holding the punch with thumb and pointer finger.
Using other hand tap on punch against one edge of clip...
clip comes right out.
Your palm prevents losing it.
Good luck.
Garcky
Twin Cities Metro Area, Minnesota
david3921
Wyoming, Michigan
That's probably it.
More like a C type since he said this, "It appears to go in a bit on the two sides (green arrows below) but not at the top (orange arrow below)." I would try needle nose on both sides at the same time and pull out. It looks like there is enough room under the clip to gain a purchase.
Garcky
In the end, they're all Jesus clips...:ROFLMAO:
Y
YoshiMoshi3
I took some pictures, it sort of looks a e-clip. It defiantly doesn't go in at the top though, slightly different.
qqzj
Since I like to use missiles to kill mosquitos, I recommend this, a small one.
Y
YoshiMoshi3
Got it off. Very interesting.
