Snap Ring Pliers Recommendation
ecotec
Interchangeable tip style retaining ring pliers are a nightmare...
gdocktor3
Connecticut
They're the exact same, different color grips. I like the Craftsman because they're comfort Grip vs channellocks vinyl.
Sam'sAutoParts
Northeast PA
Craftsman show cheaper so I would go with them, OEM must be the same for both. If sears goes out, you can always get replacement tips from Channellock.
HomeTheaterMan
As said above, they are the same pliers with the exception of the grips. I prefer the Craftsman just because they are usually cheaper and you can often get them really cheap with Shop Your Way surprise points. The ease of warranty (at least for now) is also an advantage to me.
6PTsocket
https://www.amazon.com/dp/B000RH3882/?tag=atomicindus08-20 This another way to go. It is a screw device that does both inside and outside snap rings. You adjust the tips align with the holes and go in which ever direction is needed. Unlike pliers, it is self holding so you can deal with moving the ring without having to control the squeeze. Formerly it was KD2012 with a hard red plastic handle. I have had the KD for many years. I agree that replacable tips are a pain and a full set of inside and outside pliers is better but for one tool, I like this one.
Dingleburry
Great white north in an igloo
My recommendation would be get a set dedicated to internal/external snap rings. The onnes with interchangable tips that do internal/external are what ecotech said. A nightmare. The tips are parallel. Where as the "good" (dont know about cheap sets) sets dedicated to internal/external have curved tips so your snap rings dont go flying or keep popping out of the holes.
I guess if you only do a couple here and there. You will be fine.
Had the channelock ones and they drove me insane.
ToolNuttt
I have a S.K. set which has been really good to me. Only time i needed to warranty one was when i accidentally bent the tip.
shockwave
Marietta,ga
For snap ring pliers nothing comes close that o have used to the knipex precision line
It's not us made but these are one item knipex is king on
IUEC Medic
East Bay Area
I would figure out what size snap rings you'll encounter the most, and spend the money to buy a knipex set of 4 that covers those sizes the best, then, if you have another size that you may occasionally need, get a reversible/interchangeable set that covers it. I personally hate the interchangable/reversible type. When you're using snap ring pliers with any frequency, or when your work efficiency depends on it, knipex is the only way to go. Anybody that's struggled with crappy snap ring pliers, then used knipex, will tell you the same thing. They make a huge difference.
ChevyEFI
Phoenix, AZ
The stamped style are horrible.
The interchangeable posted by OP will get ya by.
When I tired of those, the forged red handle snapons in a few sizes I needed were the upgrade of choice.
