Snap ring pliers wanted
J king
Ne oh
Hey guys. Want to get a decent set.I have some cheapie and was looking for a home shop decent quality. I don't use them much but it's frustrating when you need them and they bend! Any recommendations? Thanks
BajaBound
Nor Cal
There is a knipex set that I have been looking at. I think it has 8 different pliers.
deltaphisig
I have the channellock 927. They work pretty well, though I can't say I have used many other ones.
J
J king
Ne oh
Well they didn't bend did they? Lol. My horror freight el cheapos did.i have to admit I have used them for many years tho but the last time was the final straw.
Mohawk Dave
SoCal
I too have the Channellock 927 and the large and small older Craftsman ones (Black and red). They are the same thing. I pick them up whenever I see them so I can put different tips in each one. I like the directional switch and the big handles.
Highly recommend.
J
J king
Ne oh
I see a set of Williams on Amazon. Says they are snap on. Is this true?
bareass172
N'awlins
My buddy bought the 927's for use in his auto shop, he swears by them. I'm considering them to replace the old junkers I have that like to bend...
MattPersman
Indiana
Those Williams are probably similar to the less expensive snap ring pliers snap on sells. The forged snap on are better but also most costly but they are made by snap on in USA not a relabeled stride or similar brand.
soulstryke
Northern Alberta
I did not like the interchangeable tip snap ring pliers, so i ended up buying a few 0 degree Proto one's. I am pleased with them so far.
Loscaldazar
The interchangeable tip Craftsman/Channellock/kastar/Snap on/ and a few other brands are fantastic. One of the few "interchangeable parts" pliers that is actually worth money.
scaron
ypsilanti, michigan
try to find an old set of channellock 907s... they are my favorites. there's also a nice wilde set at epstein's for not too much money.
shopboy13
NY
MG44
Been using a 7 or 8PC HF set for a couple of years now. Have not broken one. I Make sure all the tough snap rings are not frozen before I squeeze away (Wheel Bearing)
56FordGuy
Wyoming
I had a set of Blue Points with the interchangeable tips, junk. The tips (especially the 45 and 90* ones) would twist in the little clamps. The Channel Lock type wouldn't work for me, too large to fit into some of the places I need them to go. Bought the HF set one day when I was in a pinch, they've actually worked well for a year or so. Broke the tips off a couple, bent a few others. I guess I should exchange them next time I'm near a store.
Picked up the Snap On pliers just recently, so far so good.
chrisexv6
CT
Sort of related -
A couple years ago I had to replace the ball joints on my Frontier. The Moog replacement parts were great, except for the snap rings used to retain them. I swear they were 1/8" and possibly 3/16" thick. I went thru 3 sets of snap ring pliers (including a ratcheting set from McMaster), and still couldnt open the rings enough to get them around the ball joint.
Does anyone know of a set that would have been able to do so?
Since Ive broken all the ones I had, Im looking for a replacement set. If there exists one that could do it, I would buy those....otherwise Ill just get a Craftsman set on sale.
Thanks.
-Chris
devoncoolman
quakertown pa
In regards to chris's question. I do those ball joints all the time. Yes they are hard to spread those. And any cheap or low quality set will bend or break. Snap-on's pliers are very well made also knipex are too. But the craftsman's are the same as macs or bluepoints. Still high quality and should get that job done.
HighPlainsWrencher
Sort of related -
Thanks.
-Chris
I dont know if these will work for your application but I have a set at work and use them all the time. They work great on rings that are tight. The only trouble Ive had with mine is the cap wouldn't stay tight on the threaded rod but a few drops of retaining compound fixed that. I bought mine off the Snap On truck for 70 dollars. http://www.langtools.com/hand-tools/snap-ring-pliers/68250.html
MattPersman
Indiana
I have that set too and use it on beefy bastards, some times a part of needle nose vise grips work too
chrisexv6
CT
Thanks guys, Ill take a look at those as my permanent set!
FWIW, I got the job done by ordering thinner snap rings in the same size and doubling them up, with the opening of each staggered by 180 degrees. I was just astounded (and still am, I kept them just because!) at the heft of the included rings.
kenburkholz
We used a mix of Knipex,and some huge channelocks to remove and install external snap rings on the central shaft on some large Italian production equipment. They all performed well, but the thickness of the rings made it very difficult, and marginal at best. We took a high end pair of needle nose pliers and very carefully ground the tips, making sure to keep quenching them and never letting them turn blue,these worked very well but only on internal rings. Ken.
