2ndGearRubber
I've had a run of very seized snap rings on press-in wheel bearings. Yes, sometimes I accept that burning them out is the only option.
That said, I want to make sure my snap ring plier setup is the best it can be so I can minimize destroying them.
I currently use the LANG (and others) 12 piece set ( https://www.amazon.com/dp/B005MVB6TG/?tag=atomicindus08-20 ) and a similar astro set.
Issue being, the size of the snap rings versus tip diameter. Often I can only use a .070 tip as that is all that will fit, but there is no way a set of .070 pliers could ever spread that wide.
This style seems to be the worst offender, as to requiring tiny tips. And thus having zero leverage.
I considered buying a beefy set of 18' Proto snap ring pliers, but with tip sizes listed at .103 and .110, they would be useless in my applications. Price is not a major consideration if the product can eliminate my headache/annoyances.
