Snap ring size for 3/8 Craftsmen ratchet 43784
scottybk
frenchtown nj
Anyone know the correct snap ring size for an older USA made Craftsmen 3/8 drive ratchet with ratchet model number 43784 ? This is the larger snap ring that hold the anvil's round escutcheon to the ratchet head.
I scored the ratchet for a buck at a yard sale this weekend, it cleaned and lubed up REALLY nice but of course the snap ring that holds the anvil assembly went flying during final reassembly and is MIA. Does this Harbor Freight kit have one that will work? Wouldn;t mind having spares around, I come across these older C'man ratchets all the time at yard sales and flea markets and they are easy to restore and get into service again.
Ed in Virginia
Montpelier, VA
I can't help you with the snap ring, but I can share a tip for how I assemble smaller parts/tools/? with parts like small springs, snap rings, etc. I have a see-through plastic bag that is big enough for a part like yours and my two hands, and I do the assembly inside the bag in case something goes flying. It will be retained in the bag for you.
gmcgeo
5/8" external snap ring, Yes, that kit does have 5/8" external retaining rings in it.
scottybk
frenchtown nj
It would be an internal ring, the ring is squeezed together to remove it, then squeezed and "let go" to expand into the groove in the escutcheon during reassembly. .
I'm going to buy the internal snap ring assortment at HF today and see what works. The issue is that the original snap ring does not have the little loop holes to put snap ring plier tips in, so you have to use very tiny thin needle nose. The new HF ones have the little loop circles so you can use snap ring pliers to remove/install.
Etchase
Hawaii
I don’t even know how they are sized. If I were to guess I would think it is the final installed diameter after the ring is installed and put under tension. I have an imperial and metric assortment and have been lucky to find something that worked the five times I’ve needed a new ring on ratchets.
gmcgeo
If it is internal it would be the 7/8" either way, its in the HB kit
scottybk
frenchtown nj
UPDATE: The Harbor Frieght snap ring assortment didn't work. None of them work because they are the "flat washer" style snap rings, whereas the original was a wire style snap ring. The HF snap rings are very stiff steel and I can't even get them around the eschuteon groove to compress them.
This is very frustrating. Guess I will have to order the original, which are expensive.
scottybk
frenchtown nj
Does anyone have any ideas here? I'm really aggrevated and sad now. Why couldn't Sears just use an ordinary snap ring?
Etchase
Hawaii
Just file the HF snap ring until it fits? As long as it holds the anvil in, the fit isn’t critical. Who is the manufacturer of the ratchet? That might be another source of a donor ratchet. I use a magnet to search for runaway parts with some success. You might want to search for the original part one more time.
