Drill a hole all the way through the drawer, then through the slider and used a nut and bolt or go with a large sheet metal screw. The tab just holds it in place, right? It doesn't support any weight? Can you fab up a small piece out of new metal with a tab already made and weld the entire piece on? I don't think
Welding just the tab on will work, but maybe.
They sent me new sliders for my dad's 557, old sliders (box dated 1978) had a nice twist to them from the weight on the box.
You can get a small chisel and raise the area to become a new tab.
You can also just weld a bead there and it will become the new tab. Grind the one side a little flat so the little spring thing on the slider has something to catch on.
I have done both ways
Bob
Issue is not the sliders and they told me they do not make those drawers anymore.
I guess I would have to also modify the other side so they are equal...?
