Snapped off air fitting
b7labelle
Hi all.
Bought a IR air ratchet today and didn't someone had snapped off the air fitting inside the tool. It's pretty flush with the edge of the ratchet. Any suggestions on how to get it out? I'm considering purchasing a pipe extractor, but I'm afraid it may end being too long. If that's the case I guess I could always grind it down...
Anyways, I was hoping someone on here had experience with conundrums like this and could offer helpful advice.
b7labelle
There's a little mesh screen just below the fitting... I was worried that those tools might be too long. I tried to upload photos, but it's not working from my phone....
scouting
WY, USA
Considering you probably have some files around, just lightly tap the handle end in, in my experience a file works better than the fluted extractors, and the square ones are basically the same thing. I always keep an eye open for wore out files, typically they sell for scrap price.
b7labelle
Brass, snapped off flush with the tool. I believe the proper term is "the boss"? About a 1/2 inch down there is a mesh screen. Might try to chisel idea before I head to work.
DARKSCOPE001
Pickerington Oh
get this kind. They are available in kits, and dont need to go as deep to grab. should be just what you need.
KinzeMech
I borrowed one of those hanson bits once. They are awesome.
They could call them "easy out" =)
DARKSCOPE001
Pickerington Oh
yes sir. you are correct. we use them at work. they are awesome for pulling out screws and such from aircraft. the cool part about them is that drive end. is 1/2" drive. so its big and beefy. just drill down into the screw a little. like maybe 1/8 an inch till the extractor will start to bite. then that big drive end doubles as and anvil and you can beat the **** out of it. they work great.
The original easy out is good too but they tend to wear out really fast but there is something about that easy out design that makes it bite so great. to bad they dont get big enough to remove an air fitting.
Good luck
ndoran
Sometimes the proper width cold chisel can be driven in, then turned with a wrench to remove broken pipe fittings. I have had good success with this.
I have done the same trick with 100% success, you can always grind the width of the chisel to fit
