Snappy extra deep impact sockets
NC-Fordguy
You all that have these, how are you all liking them. Do you find yourself using them often? How many sizes do you find yourself using?
I picked up just one socket today which I think will make getting gas tanks out a bit more pleasant
Murphy4570
West Deptford NJ
I've seen them advertised before in the snappy promos. They seem rather limited in size selection. Like Dave says, Standard sizes are not common anymore.
If you need an extra deep socket, go buy two sets of harbor freight sockets, take one, chop the 1/2" square drive section off, and weld the rest to the top of the second socket. Whammo blammo, extra deep socket for dirt cheap.
Specialty tools like that are rarely worth the premium tool truck price if you can easily and effectively craft your own version from readily available materials.
For example, I fabricated a leaf spring bushing installation tool earlier today for a job I had to do on a diesel Ford Excursion. Grabbed a foot long long chassis bolt in 12x1.75mm that was lying around the shop, made some adapter parts from exhaust pipe (similar to balljoint press adapters), added some anti-seize, and presto! Bushing installation tool. Total cost? $0.00.
KSB
Eastern Ontario, Canada
I have an extra deep 3/4 socket that I use for caging spring brakes, it is not a snappy, looking at the dimensions on the website I am not sure that the snap on is deep enough for that application.
Even that socket is used rarely, I usually cage with air and tighten with a wrench.
