Snow removal
Dido
Toronto
Hey, there! I hope you're doing well.
I need your wise advice! Two months ago I've started going to the gym after work 3 times a week and I now have enough physical activity, lol. In other words, I'm tired remove snow myself and I think about purchasing a snowblower. Currently, choosing from these options. Any other recommendations are welcome! Btw, spring has come and there are discounts for snowblowers, aren't there? Thanks in advance.
JRC3
Southwestern OH
For that price I'd look on Craiglist or Facebook Marketplace. Then, only run ethanol-free gas in it.
I think the only thing you could buy new for that much would be an electric that needs an extension cord...Or maybe a snow broom or battery powered. How much do you need to clear?
pelletman
Worcester, People's Republic of Massachusetts
There are snowblower forums with top 10's. If I was just doing sidewalks or a small driveway it would be a single stage toro. Larger driveway two stage. For 200 bucks all you are going to get is used, but you should be able to find something different. Hondas are awesome but over your budget
Badger 13
Northern Idaho
Might be kind of hard to find a decent snowblower in that price range. With the snow season coming to an end, now is the time to be looking. As others have said, look at craigslist, or other want ads in your area. The Toro single stage sounds like it would fill your needs, and if you do get one, absolutely use non ethanol gas.
Bigblockyeti
Upstate, SC
Find an older Toro CCR???? with a proper chute. I had one with a Suzuki 2 stroke and it worked better than my Ariens 2-stage in 95% of situations. It was light, powerful, simple and started after sitting for 8 months with ethanol gas/oil mix in the tank on the first or second pull.
HalfTonTom
Waterford, NY
OP is in Toronto. I doubt a single stage would fit the bill. Dido, unless you come across a real steal, you're not going to get much for under $300.
Parrothead
Earth
I don’t think you’re going to get anything for $200 new, so look at Facebook marketplace and hope for the best.
CJ7VFR
Central New Jersey
As JRC3 asked, how big is the area/areas you want to remove the snow from? Are you talking about a large driveway and sidewalks, along with other areas?
Or are you talking about just doing a few sidewalks and some other small areas?
For large areas, like doing an entire driveway, plus sidewalks, plus other areas, then a larger two stage snowblower is what you would want.
For doing sidewalks and maybe clearing around your vehicles a smaller one stage snowblower would work fine.
For just clearing snow off of your porch, short sidewalks and your deck, then an electric snow broom would work if you don't want to shovel it.
As others have suggested, you are not going to get a brand new single stage or a two stage snowblower for $200, even if you wait until the spring time sales. You may be able to buy a new snow broom for that. You may want to look around your local area for people selling their used snowblowers in order to get a better price. Where I live in NJ, the price of used snowblowers in good condition sell for about $300 for a single stage and they start at $450 and up for a two stage.
Jim
driz
Northern NY
https://www.snowblowerforum.com/index.php
Go see these guys! If you get a blower do make a couple impeller gap seals, ( old mud flap and a few self tapping sheet metal screws and washers)even if it’s new. Look around in the forum and you tube and you’ll see why. Your chute will likely NEVER PLUG again. If nothing else it’ll keep you from getting your fingers near the invisible guillotine which is major.
RKA
I'd look for a single stage Honda. Getting it in that price point may be difficult but this time of the year it may be possible. However, if it hasn't been maintained, expect to replace the carb if it has a lumpy idle, the paddles and scraper bar (normally all replaced as a set). That should run you about $100 and if you're reasonably handy, you can DIY it. So now it's $100 over budget, but you'll have a very stout little thrower.
Couple things to note:
1. It's meant for lighter duty work, but it's very capable. Things it can do - move up to 6 inches of heavier snow and 12" of lighter snow. Note that the heavier the snow, the shorter the throw, down it as little as 8 feet or so (in contrast to light snow getting throw 30 feet). Things it won't do (well) - the stuff the plow leaves at the end of the driveway or re-throw the snow a second time. Bear this in mind if you're dealing with heavy snow, you get one shot to throw it, if you have to throw it 15 feet, this isn't going to work.
2. In terms of the area you need to clear, it only matters with really large spaces. It only has a 20" width, so that can translate to more time outside clearing the snow compared to something with a 30" width.
3. With heavier snows, you'll need to go out multiple times during a storm to clear so you're staying within the capabilities of a single stage machine. If you can't do that, think carefully about whether a single stage is right for you Once you get beyond the boundaries outlined above, things get worse fast. You could spend 2 hours with a bit of frustration peppered in, trying to clear your driveway with a single stage where a 2 stage would knock it out in 30 mins.
I use a single stage 90% of the time, since we typically get lighter snows. The maneuverability and lighter weight make it very convenient in use. But point #3 above led me to get a 2 stage for those bigger events. I have no desire to be out there for 2+ hours screwing around with an undersized blower.
Jazz1
Thunder Bay On.
Older craftsman, 11.5 HP ,,mine is 2000 model year,,,bought new. Only replaced the auger bushings and belts to date. Excellent machines, all steel including the chute. You might have to increase budget to 3 bills on a used unit. 8hp is considered minimum but I started originally with a 5 hp TORO and my driveway 100'x30'....or call in the army:bounce:
lilredex
Toronto
You can find an 8 HP on FB marketplace for $200 especially now that the season is ending.
I inherited a 10 HP but find it is a bit cumbersome (large). When things calm down I'll look into putting that engine on a smaller 5 HP frame I have.
Don't look at less than 8 HP.....but,
A neighbour uses a single stage Honda and it seems to do OK on most types of snow.
Wait until summer and look for a used Toro 3650. Those had 6.5 hp 2 stroke (oil mix) engines and could throw snow a mile ! They can easily handle 4"-6" of snow. Over 6" and you are well over the middle of the blade.
You should be able to find one for around $200 (US).
Make sure to drain the gas out of it every spring. There is a wear/scraper bar that needs to be replaced every 1-2 years. Paddles should last about 5 years.
driz
Northern NY
Most sow thrower engine issues are a bad carb. You can usually pick up new amazon for 15-$20. If you’re willing to take a chance the unknowing often unload these poor runners for a song on Craig’s List or FB Marketplace. Parts are readily available for any of the current models , MTD, Ariens , Honda , Yardman, Cub Cadet, Deere. Nothing is all that terribly expensive either as long as you’re mechanical and can do the work yourself. Jacks Small Engine is where I got most parts for my Ariens. Common wear items Amazon
I’ll warn you one thing on belts as they’re a common wear item. PAY THE BIG$ get the OEM. For whatever reason equivalents usually are [emoji2359]. I tried.......
That forum I linked earlier is a fantastic asset for these things. These guys will surely say you straight with the particulars . Get to know those guys they’re always helpful.
tak1313
As others have said, just not enough info. A single stage would be OK if the area is small. In fact, I know some who just use those electric snow shovel for really small areas. I have a Ryobi 40v one myself that I use on a fairly large deck, and there are YT vids of people using it to clear small driveways. I do have a 2-stage for the driveway and live in NH.
I SUSPECT it may not be a very large area if he's currently doing it manually.
RAS61
Low Country, SC
You definitely want to buy quality, and I'm thinking the OP's money will go farther with gas powered than the newer battery technology. There's more maintenance with gas, so probably lower used prices since folks want simplicity?
tak1313
I hope he's found something by now since the thread is almost four years old
That's weird - I came across this on the second page of just browsing the tool forum so didn't even bother with the date. Was it a glitch?
The guy who sold landscaping equipment brought the zombie back, you and others replied, then Mr landscape equipment (apparently) got flagged as spam, post and account deleted, and now it looks like you are responsible for de zombie ing the thread. Gotta watch the history, so you know who to blame for Walking Dead XXVII being created.
JAYoung
Butte, Montana USA
Up in the mountains we rarely get wet, snowman snow, just the fluffy variety.
So I've been using a corded leaf blower quite successfully on my walkways and sidewalk. It's quicker and does a better job clearing down to the pavement.
