Snowblower parts help
ironmutt
Ill.
ok got a 1032d john deere snow blower and i need to locate a place that sells parts for it the dealers are all saying not available i need the drive system got it at auction it runs great looks good the blade spin up fine but most of the gears from the ****** are missing i have the parts diagram and know what parts i need but i cant find them any where so far . and yes i have searched google i have been cold calling john deere vintage tractor places too but no luck so any help would be nice
I
ironmutt
Ill.
ebay was a bust just tried jacks the dont carry an old parts unless made by aftermarket and cant find these aftermarket either
jakemac
New England
Check through the local papers, Craigslist, the grocery/hardware/auto stores cork-board postings, or junk/scrap yards. You're looking for any hoarders in your area that buy/sell mowers and small engine equipment. One of them might have a parts machine they'll let you raid for some cash.
oldldh
Fairhope, AL
Snow???
What the heck is "Snow"???
And why would anyone want to blow it???
(Living on the "Redneck Riviera" opens up all kinds of humorous veins...:evil:)
joe_padavano
Northern VA
Exactly what gears are you looking for? The "transmission" is a pair of friction drive disks. These turn a shaft with a chain sprocket that in turn drives the differential.
justme-
Boston suburbs
Depends on how old it is - Deere didn't make all (or even most) themselves - Ariens and Murray made them. If it's vintage (70's-80's) it's likely Ariens and going to be tough to get parts for. I would skip JD dealers and look for the OEM part numbers and sources. JD, if they didn't make the unit, would have re numbered the parts to their system rather than using the OEM numbers to "hide" the fact.
Advan
Ontario, Canada
You're going to want a parts machine, but only if you can get one cheap. Trust me, I've fixed a few snowblowers, and if you need to buy a bunch of parts, it usually better to scrap the ******* thing. Find out who actually made the machine, and you'll probably find identical units under different brands to make the search easier.
Skin
Boston
Its an Ariens 1032 painted green with a custom dash. Almost all parts are readily available through them. Give them a call with the model number or part numbers and they should be able to help you with a cross reference number to an actual Ariens part.
Steevo
43.49600, -112.04300
Go over to mytractorforum.com and look into the garden tractors section for the John Deere sub-forum.
There are literally thousands of members there who have all sorts of older machines and parts and help one another out with hard to find or obsolete parts.
I
ironmutt
Ill.
i found out a arions 1032 is same unit needed gears shafts chains friction set up the mounting housing is cracked on it too so i sold the head unit to guy to bolt on front of his lawn mower and going just set the motor on a shelf till needed the arions site list all the parts i needed but when i called to order they were all on indefinate back order
