Snowblower Replacement Skids
D45
NW INDIANA
I have a new to me Troy Bilt Storm 8526, bought for $125
Tecumseh 8.5hp
6 forward and 2 reverse speeds
Electric start
Remote chute controls
26" clearing width
Its a monster and will last me for a very longtime
It's in great shape and after a new spark plug and a new carb, it's running fantastic
I want to replace the 10" long metal skids with a polymer skid
I can't find any in this length.......should I just drill a new hole and use the shorter ones or?
Copymutt
Colorado
Not sure what the missing skids shape needs to be. First thought is cut out whats needed from tips of trashed skis.
rlitman
Long Island
Look behind the middle slot. There's the rear factory hole. Somebody already drilled this further back. I'm sure you'll be fine with regular extra long plastic skids.
D
D45
NW INDIANA
Thanks I found them on Amazon, I wasn't using the correct keywords
Polymer plastic is what I was looking for in a 10" length
D
D45
NW INDIANA
Arrived, easy installation, and is exactly what I was looking for
ronr80
ontario
I made my own with flat steel and lined the bottom with a snowmobile plastic slide . work great
Monza Harry
Windsor ON
That is an excellent approach!
Nylon or UHMW also readily available and usually not to pricey. Even a "PE" cutting board from the dollar store should suffice in a pinch or forever(ish LOL!). Harry
Edit: PE = Polyethelene cheap, cheap, cheapest!
