Toolmaker51
Where I work; long established, small, family run. That can mean the depth of experience is limited. Most common phrase, "always did it this way."
Yikes.
Hard to find a manual machine more efficient profiling work pieces than a bandsaw. I say, IMNSHO there isn't.
But free handing straight cuts requires bluing and scribing a layout, that many people can get .020 positive [.50mm] said layout.
I have order for 16 swing bolts 2" diameter, 18" long. I've made these twice before. They've freehanded them for decades. That'd be 48' [feet!] of sawing. My second piece, umm no thanks. I'll clamp a bar of CRS to table. OK, but tedious setup. Later the first op center drilled each end carefully, only way to get decent 2" threads in 2" thick stock, supported by centers, dog driven.
Pic 1All remnant and drop material. Aluminum rescued from waterjetted plate of unrelated levers. Cold rolled rail and face.
Pic 2Sliding along front rail, position secures very well via knob clamp screws. This view has cap screws in key slots and strip washer. That allows easy removal, whereas
blade obstructs each side.
Pic 3Parallel sides make setups far easier to machine. Ultimately will saw big radius off to natural, space saving angle. Interior wedges sawn by drilling, passing band blade through and rewelding. Done, just recut blade.
Pic 4Commercial hardware; cap & set screws, all thread, hand knobs, jam nuts. Clamps are slightly less spread than set screws. The set screws, fine threaded, adjust squareness.
Bare sketch of idea. No other plans needed beside tape measure.
Motivation? Factory version just under $1000.00 USD.
Yikes.
