kazlx
I picked up a Champion 80 gallon to replace a small 60 gallon that I have been using.
Long story short, I wired up a magnetic starter, hook everything up and it runs for about 30 seconds when cold before the OL protections on the motor shuts the motor off. The motor seems to get pretty hot (to the point you almost can't touch it) in the very short time of running.
I've got 240V coming in to the magnetic starter from a 30A disconnect, 240V coming out when the starter is activated, so the motor is getting 240V. The motor is a single phase only 240V Emerson, no options to re-wire for other voltages. There's only two terminals inside the plate to wire to. Everything is wired with 10g wire.
Would I be correct in assuming the motor is toast, or is there anything else it could be? I'm guessing some sort of short internally?
