SO pictogram drawer labels
VolksWomble
UK
My SO KR600 (1996 vintage) has several of the drawers labelled with small pictogram type labels. I think I’ve seen them on other peoples boxes on here - and more of them too. Infuriatingly the PO has put them on inconsistently, and invariably not on the drawers I want… so I wondered;
a) does anyone have a complete set?
and
2) if anyone had ever reproduced them, as I kind of like them…
johnre
Portland, OR
I've got this model of Brother P-touch label maker, and I normally use it standalone in the shop to print character-only labels for exactly this purpose. But I've also set it up on my laptop by connecting the USB port on it, downloading a driver, and installing their label maker app, so that I can insert my own images in the label.
You can use up to 25 mm wide tape in it, and you just pick whatever background color you want to use - but I just go with white.
It works pretty well, although there are some limitations - it's only monochrome, so no gray scale, and resolution is limited so that fine-line images get cut out. And print height maxes out at 18 mm,so the images can't be larger than that.
It's a few years old at this point, but I think it's about the same feature set as this newer model:
https://www.brother-usa.com/products/ptd610bt#carouselThumbnail
