SO torque multiplier GA185
ears
lorton VA
SO GA185 4x torque multiplier. 3/4 input 1" output 2000 ft/lbs. max. Works well guts are in good shape has some rust and grind marks the handle is engraved. 26" overall length. $150 shipped to the US.
Lost a pic somehow the grind marks are identical on both sides.
bmwpower
Interesting...
So 4 gears = 4x torque multiplier?
150 ft-lbs x 4 = 600 ft-lb
Now I can see why you jumped on it!
tjmonsen5
Crystal Lake IL
wow thats pretty cool, never knew something like this existed!
How exactly do you know how much torque you are applying though?
bmwpower
put a torque wrench on it.
input torque x 4 = output torque
medinacaver
Please excuse my ignorance on the subject,
could you provide some explanation regarding the 3/4" input 1" output. I take it the drive is 1", where is the input size.
Also counting the gearing
Housing Gear (head) = 42 teeth
Planetary Gears (each) = 14 teeth
Drive gear = 14 teeth
1 revolution of housing = 3 revolutions of drive, correct. Looks more like a speed mutiplier than a torque multiplier
again looking for an explanation to how it works
Mike83
Wisconsin
It's like a bicycle when you have the small ring in front and big ring in back - lots of pedal cranks to move the wheel one revolution, but LOTS of torque output (more likely to break something like your chain).
Generally there is about 10-15% loss through friction on those torque multipliers.
DynoDale
Pittsburgh, PA
http://en.wikipedia.org/wiki/Planetary_gear
JSBriggs
Auburn CA
The handle is for holding the head from turning. You put a 3/4" drive ratchet in the top of the head and turn the ratchet. This multiplies the torque and drives the 1" output.
-Jeff
medinacaver
Thanks for sharing the explanations. After my first reply, I googled and wiki'd and such. Lots of info out there.
I love learning about new stuff. Well new to me anyways. Its what brings me back to this site time and again
I really enjoyed finding the site where they showed some guy removing a nut the size of a bowling ball of an earth mover. I think the system cost about $3000.
I agree with others, this was a great deal.
