So undecided about placement of control cuts
Bottlecapdigger
Ontario
:dunno:Ok, I have a poured floor of 36x44 with 3 openings of 12' 2 on the side and one off set on the end. Knee wall, infloor radiant heat, 3 inches of insulation under neath, fibre cement, rebar around outside perimeter about 16" in from the wall.
The floor has be poured since about July , it's looks great, a small crack at the walkin door way. Other wise no cracks. My question is do I NEED to saw cut it at all?
If I need to I should probably do it before winter, if so how deep should it be cut?? the floor is about 5-5-1/2 " thick, Pex at the bottom of course. I was thinking cut it into 12 squares some will be a little over 10 wide or long. I would think that the cuts should not be near the edge of the 12' door but rather come out from the centre. Another thing , I plan to get a car hoist and don't want the cuts to interfere with the placement of it. I have never come across yet on how deep the cuts should be, 10,20, 30% of the thickness? This is why I keep putting this off. What do you members suggest I do?
Jo Diesel
St. Johns MI
I would cut it into 6 sections. Down the middle and divide 2 sides into 3 pieces. Pretty sure you need like 2" deep cuts.
I did not cut mine and I have a few cracks but they do not bother me.
bowhuntr311
North Central Minnesota
I would think if your gonna have issues with cracking its gonna be in the winter/spring when your ground freezes/thaws. Any contraction/expansion cracking related to the concrete curing would have happened by now. With rebar and fiber a person would hope it will not crack but I'd rather cut it than have it crack.
Dick in Wisconsin
Shawano, Wisconsin
My concrete guy did the saw cuts the morning after the pour. I have a pex, insulation, etc probably just like you did.
After the race shop was finished and I started to use it, I realized I should have dictated where the saw cuts were. I back a trailer up to one of the doors to load a race car. The driveway should have had saw cuts just outside of where the trailer tires needed to be so I had something to guide the trailer in with.
Inside I should have had the saw cuts make a rectangle where I would park the race cars so it would be very easy to get the cars located in the middle of their respective stalls.
I also would have like to have had a saw cut in the shop at the center of each opening.
Hindsight is always 20/20. Maybe you can benefit from some of mine.
