Rodhotz
On a main panel, from a 125 amp to a 225 amp with permits and stucco repair. Thinking about going to solar and got quoted 2100 from them, fair or not?
An upgrade to 200A in SoCal from what I have seen on many message boards is quite often in the $3000-$3500 range. It's the whole crazy outdoor panel embedded in stucco thing, besides SoCal being off the charts expensive for any kind of work.
A) Your quote might not be a complete service upgrade.
B) If so then I don't know how they would get away with just replacing a 100A panel with 200A.
Yes they are doing the stucco but as you said not hard at all to patch, no weather head as it is underground feed. I have done them in the past mostly because i was to broke to pay someone to do it. The one they want to put in is huge, like 3 1/2 'x 2'.
Compared to a panel surface mounted on a nice plywood back board in an unfinished 8' ceiling basement with all the room in the world and no obstacles and easy access any time in the future (like many of ours are), yes, it IS crazy!Not sure what is so crazy about having your panel in the wall with stucco around it....I like stucco....easy to do...easy to fix....
Compared to a panel surface mounted on a nice plywood back board in an unfinished 8' ceiling basement with all the room in the world and no obstacles and easy access any time in the future (like many of ours are), yes, it IS crazy!![]()
Oh, I'm not knocking stucco at all. It's a great material. It's outdoor panels flush mounted I am knocking.Out here stucco is a great material for walls. Cheap...strong...easy to repair...and it does pretty good in earthquakes.
Even flush mounted in a garage is light years better than outdoors and flush. Snaking into one later must be 2 man work every time, huh?
Since the feed from the PoCo is underground, have u checked with the PoCo to make sure the conductors are rated for 200a service?
Flush mounted panels in stucco are a royal pain in the ****!
